Missle strikes A300
  • Thread starter Thread starter ~~~^~~~
  • Watchers Watchers 2
Aviation Week & Space Technology Login|Subscribe |Register
DHL/EAT Crew Lands A300 With No Hydraulics After Being Hit By Missile
By David Hughes and Michael A. Dornheim
December 7, 2003
No Flight Controls
In a situation reminiscent of the United Airlines DC-10 landing without hydraulics in Iowa in 1989, the crew of a DHL A300 hit by a missile relied solely on engine power without flight controls to land at Baghdad.
Pierre Ghyoot, secretary general of the Belgian Cockpit Assn. (BeCA), told Aviation Week & Space Technology that the pilots were able to guide the aircraft to a safe landing on Nov. 22 using only engine power settings. The aircraft lost all three hydraulic systems and all flight controls. Ghyoot said his organization is already planning to give the crew a safety award.
According to one aviation source familiar with the incident in Baghdad, the incredible feat of airmanship is explained partly by a safety seminar the DHL/European Air Transport (EAT) captain attended in Brussels earlier this year. In a stroke of luck, one of the speakers was retired Capt. Al Haynes. In 1989, Haynes commanded a United Airlines DC-10 in which all the hydraulics had been lost due to a center engine rotor burst in cruise. Using engine thrust alone, the United crew was able to crash-land the crippled aircraft at the Sioux City, Iowa, airport, and the majority of the passengers survived.
After the DC-10 accident, studies and flight tests by McDonnell Douglas and NASA Dryden Flight Research Center showed engine thrust can be a control in some cases and that practice before landing is extremely valuable (AW&ST June 24, 1991, p. 43). NASA research pilot C. Gordon Fullerton noted the primary job is to damp roller-coaster phugoid oscillations in pitch and find a stable attitude. Adding thrust with underslung engines like the A300 tends to pitch the nose up. "You have to devote maximum attention to the position of the nose and keep pitch rates low," Fullerton said. Turning the aircraft is done with differential thrust.
NASA experience with landing a simulated Boeing 720 using manual control of thrust was "very iffy," but the agency and McDonnell Douglas modified an MD-11 with software to control the engines, and flight test showed it could make airline-quality landings using thrust alone. But for manual control, Fullerton suggested finding as large a landing area as possible, such as the lakebed runways of Edwards AFB, Calif. However, that presumes aircraft condition is not deteriorating, and the DHL aircraft's wing was on fire.
The DHL/EAT crew headed the aircraft back to Baghdad International after it was hit at 8,000 ft. on climbout from the airport. Normal DHL procedure at Baghdad is to make a steep climb to avoid attack. Takeoff configuration is slats extended with zero flap, and that is maintained in a 160-170-kt. climb to 10,000 ft. Then the slats are retracted and the aircraft accelerates to a normal 300-kt. climb speed. The flight was still in this low-speed climb when it was hit.
When the missile exploded, the crew first thought an engine had suffered an uncontained failure, but all readings were normal, the aviation source said. Then the hydraulic pressures started dropping and a ground call told them the wing was trailing smoke. The captain could see that the wing was on fire.
Damage, presumably from the missile blast, is concentrated at the left trailing edge along the outboard flap, between the engine and the outboard aileron. The outer half of the outboard flap is missing, and the outboard flap track is dangling from the bottom of the wing. About 10 ft. of the rear spar is broken open or missing, and fire-damaged ribs are visible inside the outboard structural fuel tank.
All hydraulic pressure was lost about a minute after the hit, the source said. The low-speed aileron outboard of the damage is supplied by all three hydraulic systems, and there are five spoilers in front of the outboard flap, fed by the three systems.
Primary flight controls become inoperative on the A300B4 with total loss of hydraulic pressure, because there is no manual reversion. The stabilizer trim froze because it is powered only by a pair of hydraulic motors. The crew deployed the ram air turbine with hydraulic pump, but the leaks rendered it ineffective.
The crew had problems controlling the aircraft and at times didn't think they would make it, the source said. But the captain recalled the Haynes presentation and started using engine thrust for control, and was surprised to find it worked rather well.
The aircraft circled twice while the crew manually extended the landing gear. Ghyoot said the pilots lined the aircraft up for a flat, straight-in approach from 20 naut. mi. out and that the approach and landing speeds were 225 kt., though the source said touchdown was around 180 kt. "Having the trim set right when they were hit saved them," the source said. Ghyoot said he believes the aircraft had flaps retracted, but the brakes worked as they were powered by an isolated hydraulic accumulator.
The crew aimed for runway 33 Right, but at short final were thrown off course and decided to try to land on runway 33 Left but were not properly lined up at touchdown. A photo shows the aircraft touching down on the runway on the right wheel, banked a few degrees to the right, and in a slightly nose-up attitude. The aircraft ran off the left side of the runway and went through barbed wires, fences, and dirt before coming to a stop near the fire station. Full reverse was applied, causing a large dust cloud. Both engines were damaged by debris.
A Paris Match magazine freelance photographer was with the attackers and shot pictures of the missile launch and strike, which are in the Nov. 27 issue.
Ghyoot said the U.S. Defense Dept. is investigating the missile attack, and then the Belgian Civil Aviation Authority's accident investigation service will conduct the final phase on the civil aspects. A Belgian criminal investigation is underway.
DHL was carrying U.S. mail to troops in Baghdad but shut down this operation for about a week after the missile attack. The 1979 vintage A300B4-203F was operated by DHL/EAT with two Belgian pilots and a British flight engineer. DHL offficials said the aircraft will eventually be repaired.
In the past 25 years there have been 35 shoulder-fired missile attacks on civil aircraft, 24 resulting in crashes with 500 fatalities, according to AOC, the electronic warfare and information operations association, in Alexandria, Va. The U.S. Homeland Security Dept. is about to pick contractors to develop prototype missile-self defense systems for use on commercial aircraft (AW&ST Dec. 1, p. 46).
jeebus, dude, welcome to last week
not only that, we've allready flamed Airbus, the Iraqis and the Prez on the same forty threads resulting from the DHL taking a heater
waste your bandwidth wisely
FlyChicaga said:
Vlad I'm so happy we have you here to keep us in check. :p
must you torment me for speaking out on behalf of countless flightinfo regulars, shocked at finding yet another mirror like article detailing the heroics of the belgian DHL pilots, Son of Chicago?
reposts are serrious business, Son of Chicago
you would have netted yourself a comfy, 3 decade stay at the Gulag Inn had this offense taken place in the Motherland
In the past 25 years there have been 35 shoulder-fired missile attacks on civil aircraft, 24 resulting in crashes with 500 fatalities...
That doesn't, of course, take into account the shootdown of TWA 800.
When you posted that did you cringe, just waiting to see what happens next? :D
We haven't flamed the French yet!
Curious that a Frog photographer was tagging along with the Iraqis to watch them try to shoot down a civilian airliner.
I wonder why a freelance US photographer wouldn't have been trusted to do that?
Hmmm. Funny too that it was a French Mistral missle that was found in New Jersey not long prior to the TWA "accident."
Nuke the french. Anybody that eats snails...
Yeah, Jim, I've heard it all before, and I remember very well your assertions that a MANPADS could never do this...you were wrong then, as well as now.
Multiple light surface to air packages exist and are available on the world market that could have been used here. You'll note that I didn't say a word about you and your squadron playing a part. You had your day, and I don't think anyone would suggest that it was an aegis cruiser or a P-3, X files aside.
There is no question that a week prior to the shootdown, a missle was fired from a boat in the same location, or that a missle was found on it's launcher just before that, on the east coast. Or that US intelligence knew that missles were enroute to the US and that rumint suggested that a missle attack was being planned, or that Saddam was sponsoring the effort...yada, yada, yada. Or that certain experts at China Lake noted that it had to be a missle attack. Or...we could fill volumes with every reason in the world why this was a missle attack and not an internal, independent explosion.
Don't get so defensive. It's not about you. It's about a terrorist act that was suppressed to help the public feel good about themselves at the time...before today when the public is stirred up to go to war, to feel good about themselves and their lying, incompetent CiC.
Or did I say too much?
Jim said:
And of course he hasn't told the coalition authorities who the Iraqis were. Can't give up his source - it won't be professional. He should give them up or be arrested for interfering with an investigation and conspiracy to terrorism.
Naw, don't arrest him for conspiracy. Let him go clear mine fields.
Don't apologise for the phone comments. If you worked for Southern Command and received intel from Ft. Huachuca, then you're more than familiar with listening to phone conversations. After all...how did we get Escobar? His cell phone.
I don't think anything I stated regarding colombia has been dramatic. What goes on there sometimes is, however.
"Plan Colombia" is nothing more than an extention of financial aid for programs that have been in use in that region, and farther up north into Mexico, for more than 20 years.
I wouldn't brag about US intelligence...the community is still cowering from the political fallout following September 11th. That you had no intel available to you personally identifying the TWA 800 event as a terrorist act isn't surprising, though I'm not certain I believe it. That it was a terrorist act is really not even a question. That it could have been anything other than a terrorist act has never been proven, and cannot be proven.
So don't keep your peace. Tell me about the drama of plan colombia. I'm all ears.
Being done is good. You crossed over into classified when you touched on military training, and transfers.
We provide advisors. COLAR and CNP do the fighting (uh-huh:rolleyes: ). That's all you need to remember.
The transfers are congressionally approved and mandated, and they're not military transfers.
Yes, there's significant military involvement. There has been for a long time. The level of that involvement has never been public. Then again, neither has the fact that the real fighting isn't about drugs or colombian sovereignty, but about Al Gore's pipeline. We can't talk about that either, can we? Nor about direct action involving much more than advisory sevices by us special operations.
Plan colombia from an eradication point of view is about crop dusting, period.
Plan colombia is largely a financial package. Colombia is the largest recipient of US foriegn aid in the world. I can tell you that it's not all going into the spray program. And like you, there's a lot that cannot, and should not, be told.
No Jim, you stated that you couldn't remember what was classified, and what was not, remember?
quite frankly, I can't remember what is classified and what is not.
My suggestion is that any references to that material, especially any concerning military invovlement (a very delicate area regarding plan colombia) be reserved for private conversation between interested and authorized parties only. The inference that the military is invovled isn't classified, but most certainly the degree to which the military is inolved, is.
As for being one of four people who developed plan colombia, I disagree. Perhaps one of four who developed plans to coordinate southern command with the operation...but who developed plan colombia? That's more than a minor exaggeration.
