BoDEAN
Cabo Wabo Express
- May 4, 2002
Studying for an upcoming interview, and want to make sure I am clear on some points. (All questions refer to 121 / Jepp Plates)
1) To know if a runway has/uses RVR, the only place to get this information is on the back of the airport diagram on the Jepp plates?
2) Takeoff minimums. These are also found on the back of the airport diagram. As far as needing a takeoff minimum, I am a little confused on this one. I have been trying to understand page 125 in the Jepp intro. This gets into RVR #'s, and what needs to be inop, what can be replaced, and so on. If anyone has a nice clean way of clearing this up I would appreciate it.
3) Part 121 alternates, departure alternates, when do you need an alternate? Basically, the 1-2-3 rule. 1 hour before to 1 hour after ETA, ceiling must be at least 2000 ft and 3 SM. If it is not, you must file an alternate. An approved alternate must have an instrument approach procedure. Fuel requirements for an alternate are 45 minutes. When do you need an alternate for an alternate? As far as a departure alternate, if the weather is below the approach minimums, you must file a departure alternate?
4) If the weather goes below mins after the marker, may you proceed on the approach? I would say yes. If prior to reaching the FAF, the weather is below minimums, I believe 121 operators are not permitted to fly the approach. Once on the approach, it is ok.
5) Part 121 Flight / Duty times:
I know the flight times are 8/30/100/1000 . Not to sure on the duty times.
Thanks in advance
Thanks in advance
