philo beddoe
- Jun 21, 2004
That's what I've trying to figure out as I read this. When I was taught instruments my (bloody good) instructor told me to go below a minimum altitude was an instant checkride bust. So what if that's not what the PTS says or the regs etc. Forget about trying to figure out how far you can be below or what errors may be, set your altimeter and make your goal to be above the minimums with +50'.avbug said:How much below published minimums can you fly? Minimums minus zero...and you can certainly be above them. Why would you permit yourself to go below a minimum at all?
You folks really need to go back and read the original question. I thought I pointed this out already, but perhaps it was overlooked.JRSLim said:That's what I've trying to figure out as I read this.
Well he was wrong, it is not. If an examiner busts an applicant for being 30 feet below a procedure turn altitude, the examiner is in the wrong.JRSLim said:When I was taught instruments my (bloody good) instructor told me to go below a minimum altitude was an instant checkride bust.
That is excellent advice, however it fails to address the question which was asked.JRSLim said:Forget about trying to figure out how far you can be below or what errors may be, set your altimeter and make your goal to be above the minimums with +50'..
A Squared said:You folks really need to go back and read the original question. I thought I pointed this out already, but perhaps it was overlooked.
The question is how low below PT altitude constitutes a violation of the regulations. Nobody has asked about how far below *should* you go, nor has anyone *advocated* going below an altitude.
There is a difference between a limit and a goal. The student should know the limits, and have more demanding goals. If he thinks the goal is the limit, a small mistake can have an adverse effect.JRSLim said:Why teach a student to fly thinking +-100 feet if you can teach them to fly +-50 or 20 feet.
§ 91.177 Minimum altitudes for IFR operations.You folks really need to go back and read the original question. I thought I pointed this out already, but perhaps it was overlooked.
TonyC said:There is a difference between a limit and a goal. The student should know the limits, and have more demanding goals. If he thinks the goal is the limit, a small mistake can have an adverse effect.
When he's taking the checkride and happens to miss that goal, he can do one of two things. He can think he has just busted the ride by exceeding a limit, and let that failure adversely affect his performance from that point on. Or, he can realize that he missed the goal but still met the limit, and he can continue the ride without distraction. If he confuses the two, you've done him a disservice.
We also have 2,000' obstacle clearance over mountainous terrain, right?philo beddoe said:Also, temp errors can be considered, but the most likely place for real peril to occur would be a medium to high PT in mountainous terrain, with very cold temperatures.
This is because the cold-wx error compounds with altitude above the altimeter reporting station, not your height MSL.
That is such an excellent point. I've had ground prox warnings on cold days in mountainous terrain in Oregon and Montana while being vectored. Querying the controller about their MVA's has revealed that they are 1000 agl and they make no correction on cold days, meaning they think you are 1000 agl because that is what your mode C reports, but in reality you are lower due to non-standard temperature as revealed by your radar altimeter and ground prox. Why ATC can't feed temperature into their computers like they do non-standard pressure is beyond me.philo beddoe said:Not on prcedure segments.
Just MEA's, MOCA's, and grid MORA's.
Not even on MSA's.
Y'all be careful out there!
