• This site moved from forums.flightinfo.com to flightinfo.com. Please update your bookmarks.
Military to FAA Flight Time Conversion
FL510GV
Junior Birdman
Total Time
7500+
JetBlue Update
It's been updated to include the JetBlue 1.3 conversion.
FL510GV
Junior Birdman
Total Time
7500+
UPS PIC and conversion
Don't know the answer to the UPS conversion question, but have seen/heard that they will accept Part 61 "sole manipulator" PIC. If anyone out there knows the UPS answer, give me a valid reference (website or UPS policy letter etc) and I can fix the spreadsheet.
FL510GV
Junior Birdman
Total Time
7500+
EJA Convert
EJA/EJI/EJM
They accept a .2 per sortie conversion factor... just like FedEx. I have been unable to find a documented source for this, but I have two "high-up" contacts (people doing hiring/interviews) who have stated as much.
Good Luck.
KODI#
New member
Total Time
2600
Flt time to FAA
Can you direct me to the appropriate place for deciphering Mil time translated to PIC? As per CG log books, I've got 500hrs where I actually "signed" for the plane but have over 800hrs time since upgrade to Aircraft Cmdr (AC). Do companies also count the FPT where you were the "sole manipulator" of the controls, even if not yet rated as AC, AS PIC?
Thanx for the spreadsheet!!
zulua320
Nothing Special
Total Time
2500
KODI#,
Each airline has its own specifics on how they want you to log PIC, and tend to spell it out pretty clearly in the application. Most only want the time you actually signed for the aircraft, while at least a few (SWA included, I think, but don't quote me) allow you to log all time after upgrade to AC as PIC (regardless of your actual position). The bottom line is that you appear to have a pretty good handle on your hours picture -- keep tracking it as you've been doing, read each application carefully, and log it the way the specific airline wants it (sts).
FL510GV
Junior Birdman
Total Time
7500+
KODI#
I have a fairly extensive explanation of PIC/SIC and Part 1/Part 61 on the website for the spreadsheet. In the explanation of the spreadsheet there are also links for the airlines that I know take some type of conversion and they explain there how/why.
Zulua320 is right... just about every airline will be specific as to how they want the time, just be sure and fill in their specific app the way they want it.
Student time, whether it's sole manipulator or not, is student time. You may count it, generally, toward your total time, but not toward your PIC/SIC. Most airlines don't want Par 61 (sole manipulator) counted, but a lot of Corporate and others will take it. Just be careful.
Let me know if you have any other questions.
skiddriver
Total Time
5000+
Execjet conversion
The 1.2 conversion was specified on the "PILOTS REQUIREMENTS FOR APPLYING AT EXECUTIVE JET AVIATION" sheet that came with my application package. It's in the bulletized list at the top of the page in the same line as the 500 hour fixed-wing multiengine time requirement.
I didn't need it, but it helped one of my friends get hired last year.
Make sure you have the same sheet in your app pack and that it still reads the same before you use this conversion.
Good luck...
F18-FDX
Purple Rules
Total Time
4000+
Great info, but as zulua320 mentioned, almost every airline will want different things, some tell you specifically NOT to convert your time, they will do it. Just read the app. very carefully because you don't want to show up to the interview and realize you made a mistake. This could put you into the "doesn't follow directions" or "overstated flight time" category, even if it was unintentional.
F18-FDX
Purple Rules
Total Time
4000+
There really isn't any such thing as "FAA" flight time. The general discussion is that many airlines allow a "plus up" conversion factor to military flight time. We normally log takeoff to landing plus 5 minutes taxi time, however the civilians log engine start to shutdown, or hobs. As posted, they'll normally allow you to multiply your time by about 1.1-1.3 to put you on a more equal level, flight-time wise with the civilians. The most important thing is to read the specific airline app carefully, as I said, they are all different and some want only straight logged time.
