metar help
cforst513
Giggity giggity goo!!!
METAR KSPG 250053Z AUTO 02007KT 10SM CLR 31/25 A2992 RMK AO2 SLP131
T03060250 TSNO
what does the bolded/italicized part of this metar mean? and where can i find a list of metar explanations? in the AIM?
T03060250 TSNO
It's coded temperature and dewpoint. T means Temperature I assume. The first four digits are the temperature. In this example the temp is 30.6C. The last four numbers are dewpoint: 25.0C. If 1's were the first or fifth number that would mean a negative reading.
only a government body would see fit to duplicate a part of such a printout, the T/DP are already listed. But can they provide universal uncoded weather to people? Noo-oo. Even if we are now out of the teletype age where every digit is sacred.
No kidding. The main body is easy enough to figure out, but they sure get creative in the remarks.
Actually, the reason temperatures and dewpoints are in the remarks are for the general public. As pilots we only need to know temp to the nearest degree C for most of our performance and weight and balance. However, when we changed from the old code (which used degrees F) to METAR the general public and meteorologist types thought degrees C was too "crude" of a scale.
As a side note, if you do have a unaugmented AWOS/ASOS ("AUTO") that is capable of reporting thunderstorms: BE CAREFUL! Most of the time they report lightning "DSNT" regardless of how close the thunderstorm is.
Speaking of which, anyone know just how far out these automated stations can detect these thunderstorms and lightning?
oh for gawds sakes, the public needs to know to the decimal what temp it is outside? Most of them couldnt guess the correct temp within 5 degrees.
i know i cant
