tathepilot
- Oct 5, 2003
I'm looking for a few formulas..
When you get the crossing restriction:
1. Flight idle
2. Spoiler extend
3. MMO or VNE whichever is less
At any time if Center asks if you can make it:
1. Say "no problem"
2. Gear down
3 Flaps extend
4 Pray.
Never missed one yet
Groundspeed add a zero /2 gives you 3 degree glide path.
400 knots = 4000/2 = 2000 fpm for a 3 degree decent
Altitude to loose 410 to cross "BAILL" at 11,000
30,000 / 2000 fpm = 15 minutes out from your crossing restriction begin decent.
Or you can press VNAV on the G530 and it will do it all for you.
You can take the altitude you need to lose divided by 1000 and multiply it by 3.
Example:
You want to descend from FL350 to FL200. Take 15 x 3 = begin descent 45 miles out.
Multiply your ground speed by 5 to determine the approximate ft/min descent rate for a 3.0 degree glide path.
I don't think about it in minutes but i do something similar.
410 to cross baill at 11000. 30000' to loose thats 90miles out.
If im averaging 400 knots GS I add a zero to 400 (4000) then divide by 2. 2000fpm
so 90miles from baill i start a 2000fpm descent.
