Mental math for crossing restrictions..??
If you get a crossing restriction when you are 90 miles from the fix, are saying that you start a descent as soon as you get the restriction..??
BushwickBill used 90 miles as an example of when he got the crossing restriction. How does 90 miles fit into your example..??
90nm is 3x the altitude to be lost, or 30,000. Another way of stating the 3 to 1 rule.
To cross Baill @11000 you would leave 410 approximately 90nm from Baill.
Here's what I like use...
Altitude to descend to fix, divided by 5000. Say your at 35,000 and need to cross BOZZO at 10,000 and 250k (25,000 / 5000 = 5)
Take the result, then when you get about 5 min from BOZZO, do the following...
1. Deploy Inboard Reverser's to Reverse Power Stop
2. Hold VMO
3. Shut up the screaming jumpseaters (or your engineer)
4. Level off, Stow Reverser's
Then you have about 10 miles to slow to 250k
No Problem, works every time!
No you would probably get that clearance 150 miles out or further. But when the plane says your 90 miles from the fix, you start down.
The phrase you want to hear is N1234A descend 240 at pilots discretion expect ABCDE at 11,000. BTW ABCDE at 11,000 is on you arrival plate and you should have been thinking of that a long time ago. Then you can wait until your going to need a 2000 fpm decent and start down. The logic is that you'll save tons of fuel and maintain a higher true airspeed by staying up high.
Whats with you guys using distance? Nothing wrong with it but I have always used time. It is available for both DME and GPS, although we rarely use DME unless the procedure calls for it. Since your true airspeed is decreasing in the decent your not going to get an exact time to start down anyway.
