Fearless Tower
- Mar 28, 2006
- Total Time
- some
I was getting checked out in the local flying club Duchess the other day and during the flight, the MEI I was with had me fly a simulated engine failure on takeoff with the gear down still down. I responded by pulling back the throttles and establishing a controlled descent to the simulated field elevation which is how I had previously briefed the takeoff and in accordance with all of my multi training. The instructor explained that what he had wanted me to do was immediately raise the gear and feather the affected prop. We took a time out so to speak to discuss this event and his explanation was that the maneuver was something that he had always been asked to demonstrate in checkouts and flight reviews. His thoughts were that if you no no useable runway remaining then you were better off getting the gear up and trying to keep the plane in the air.
The problem I have with such a demonstration is that it is clearly contrary to current FAA guidance that I have seen as well as contrary to what is published in the Airplane Flying Handbook. If your criteria for raising the gear is positive rate and insufficient runway remaining then you would still have runway/overrun available if you lost your engine with the gear still down. If not, then you would have already selected gear up. In a light twin, I do not see the point in having someone demonstrate such a conflicting procedure. To me it seems alot like the single engine failure on takeoff 180 turn to return to the runway. Still CFI's that teach that and still alot of people getting killed trying to accomplish it.
At any rate, I realize this may stir up some debate, but I am curious to hear what other MEIs are teaching/training with regards to this.
To clarify - I'm talking specifically about light twins, not transport category aircraft and/or aircraft with published V1/V2 speeds.
