Medical waivers for the military?
JSky26
Hello,
I know this topic has probably been picked to death but I can't seem to find any straight answers anywhere else.
I have a current FAA 1st Class medical through waiver. My best corrected distant acuity in my left eye is 20/25. Everything else is 20/20 all around. I also have a mild red/green color deficiency. I have trouble getting the last couple ishihara plates but I have taken the Farnsworth Lantern test and can pass that easily. I have no problem discemenating these colors in my flight experience thus far...
But bottom line, if I play may cards right, can I be a military aviator? Or am I destined to stay on the civilian side?
It depends on what type of military aviator. If you went mil. you would probably have to stick with cargo. For Fighter pilots its 20/20 uncorrected(non-waiverable), so I dont think that your vision will cut it here. I'm not sure about the color problem, I thought that was waiverable, but maybe not, it probably depends on how bad it is.
USAF UPT requirements
Looks like your color deficiency would be a show-stopper in the USAF. Don't know about other services but my guess is it's probably a no-go.
Before Selection for Undergraduate Pilot Training: Minimum Requirements
-Under the age of 30 prior to beginning flight training
-Minimum 20/70 vision correctable to 20/20 without color blindness. Laser vision correction (RK, Lasik etc.) is disqualifying
-Bachelors Degree
-Applicant must be physically fit and able to run 1½ miles in under 12 minutes
-Meet Air Force height and weight requirements
The info posted above this is not correct. There are plenty of fighter pilots in the USAF who are not 20/20 and wear contacts or glasses when they fly. There is no separate criterion for fighter pilots vs. cargo pilots - you are either physically qualified to become a pilot or you are not.
JSky26 said:
Hello,
As someone who had an F-16 slot in the Guard, but then lost it due to a mild red/green color deficiency, I'll go out on a limb here and say you are probably destined to the civilian realm. But regardless, make sure you go and take the Flying Class 1 physical somewhere...you never know how you will do until you actually take the test. Good luck!
-Neal
Thanks for the responses guys...
I was just curious... I never thought military until all these flight fees started adding up. I'd be done with college in two years and I heard about some guys that just applied to OTS or something like that and got slots? They weren't even in ROTC which I didn't know you could go that route. But I'll pay them off one day on that lowly regional FO salary.... Thanks again
BlueDevAv8r,
You never had a problem with any of your employers regarding your color deficiency? Do you have a SODA or did you take an alternate test with the FAA?
BlueDevAv8r,
No, I don't have a SODA. I took the FALANT test at a civilian doctor's office (was in the NY School Of Optometry or something like that) and then mailed those results to the FAA in OKC. They then sent me back a letter saying that I passed an alternate but approved test and I don't have to have my color vision tested on any subsequent medical exams. In other words, my 1st Class Medical looks normal (except for the "must wear corrective lenses" line).
-Neal
Josh you're talking out of your A$$. All UPT students are held to the same vision standards upon entering training WAY BEFORE they know if they get to fly a fighter or not. Last I checked it was 20/70 or better without a waiver. As already stated, if you have color vision issues, you may have a problem.
-Neal
What unit and when was your slot?
121FS, 113FW, DCANG...way back in 1999. It was for a FY00 slot if I remember correctly (but I try to block it out obviously...it hurts to even think about it). :D
-Neal
