If you stay under five airplanes and five pilots, you can operate as a Basic Operator, whereby you do not need all of the 14 CFR 119 management personnel.Does anyone know if it allowable under 135 for 1 person to be the President, VP Flt Ops, and Chief Pilot, of an operation at the same time? Or would this be too much operational control for one person.
Yes, you are absolutely right. I should have clarified the "More Than Nine Passengers" aspect of the rule.While that may be true from a regulatory standard, if one of these aircraft is a 10 or more, you will not get far without separate individuals in most spots, at least D/O, CP, and D of M.. Then the other thing is who is the owner, not so much the title of president.
