NYCPilot
Incorporated.
- Nov 29, 2001
Okay, I’m trying to gain a better understanding of mach flight and the negative aerodynamic effects encountered when shockwaves are formed. Please add to or correct anything. Thanks.
Here it is as I understand it.
At speeds encountered during transonic flight (MACH .75 -1.20), compressibility effects begin to manifest themselves which in turn produce shockwaves to form.
Effects of compressibility are:
Shockwaves
Airflow separation
Drag increase
Control & stability problems
Buffeting
The critical MACH number is the speed that the airplane is traveling when a portion of the airflow over the wing first reaches MACH one.
Jet aircraft are most efficient at speeds within 5-10% of MACH one.
A shockwave is the dividing point between undisturbed and compressed air. Air ahead of the wing traveling at Mach 1 is compressed and has a higher pressure and density than the undisturbed air ahead of it. When this compressed air meets the undisturbed air, it forms a shockwave. A shockwave that is perpendicular to the airflow would be called a “normal” shockwave.
When this shockwave occurs on a portion of the wing, airflow traveling through it cause the supersonic air ahead of the shockwave to penetrate the shockwave and slow down. This air, now behind the shockwave has slowed down and increased in temperature, density and pressure. This disturbed air has now caused boundary layer separation on the wing which causes airflow separation. The separation has the effect of decreasing lift which leads to less downwash from the wing which causes turbulence at the trailing edge and causes the center of pressure to move aft. The turbulence formed at the trailing edge alongwith the C.P. moving aft has the combined effect of creating “MACH TUCK” which is basically a pitching down of the nose.
Also, what about coffin corner.
As altitude increases, TAS increases but the speed of sound decreases as temperature decreases. This causes the limiting Vmo or Mmo to decrease for a given % of MACH. In other words, the IAS for M.O. speed will decrease as altitude is increased.
How does this affect the stall speed and how does it create a corner you don’t want to get painted into. Stall speed increases but MACH IAS decreases??
Shockwaves
Airflow separation
Drag increase
Buffeting
