It doesn’t really make any difference at all. There are those who will say that “high-wing” trainers such as the Cessna 152 or 172 are easier to fly and are more stable. Others will say that the “low-wing” aircraft such as the Pipers are better. The truth is that either type is just fine. Each type has its particular “pros” and “cons”. There might be some argument for using a high-wing trainer if someday you dream of owning a Cessna 210 or a low-wing trainer if someday you plan on buying a Bonanza or other high performance low-wing aircraft. However, when all is said and done it doesn’t really matter. You can safely base your decision on what “strikes your fancy” and where you can make the best deal. What does matter is who your CFI is. Take some time and find a good one.cforst513 said:is there an advantage in learning how to fly in low-wing aircraft vs. high-wing (or vice versa)? maybe tomahawks and archers vs. 152's and 172's. what do you guys prefer, or what did you learn on?
rumpletumbler said:We rent the Alarus for $78 an hour. I'll bet it is far better equipped and much newer than your 152 as well.
http://www.newplane.com/amd_files/Alarus-2005-13Ss.jpg
