Low wing fuel system vrs high wing
Bernoulli said:
Good point. engine driven fuel pump not strong enough to push or pull from both tanks and pump could suck air from a low tank.
FYI: fuel pumps never push, they can only pull the fluid.
That is incorrect. A fuel pump draws, or "pulls" fluid to the pump. From the pressure side of the pump, it's all "push." Pumps are used to not only draw fluid and "push" it somewhere, but to "push" it under pressure or boost pressure to a useful value. The "pull" or inlet side of the pump is the low pressure side. The pump output or "push" side of the pump is the pressure side and it is very much pushing the fuel.
Bernoulli said:
Anyone know why the fuel selectors on single engine low wing airplanes never have a "BOTH" selection. It's always left or right which begs for human error
My humble opinion is that you have it backwards.
Would you rather have the engine stumble, sucking fumes when you had the selector in the 'both' position...................or in 'right'/'left' position? The human-error thing can bite a lot harder with that danged 'both' position!
C'mon, we are pilots. We can manage fuel.
Ummm...close. That push is ONLY there because of the associated pulling action. You cannot have a one-ended pump and expect it to push a fluid. There has to also be a pull to create that. Therefore, pumps pull, not push. We're splitting hairs here, ya know?
There's no splitting hairs. Pumps move fluid, true enough. But the output side of the pump is under pressure, and fluid is being moved to a location. Pumps usually don't draw from a source, they push to a source.
This is important. It's for this reason that many low pressure pumps and engine driven pumps don't have the ability to suction feed, or can do so for only a short period of time. These pumps are life limited on suction feed. On a suction feed operation, the pump is "pulling." However many of these systems, indeed most all turbine installations, need to have fuel fed to them under pressure. The purpose of the pump is to push fuel somewhere, under pressure, at a higher pressure than it's taken in. Boost pumps are there to boost fuel pressure and maintain a line pressure. Often these pumps are submerged, and are being fed by a resorvoir or tank which surrounds the pump. On more complex aircraft that utilize jet pumps, this is handled a little differently, but many aircraft still use submersible pumps.
These pumps draw off surrounding fluid, or a feed to the fluid, which often arrives under it's own head pressure from tank pressure or the weight of the fluid. From here it pumps, or pushes the fluid under pressure to a destination. That may be another customer pump, or an accessory/engine pump, such as an engine driven low pressure pump.
In many cases, the purpose of this pump isn't just to push fuel to the engine, resorvoir, header tank, or other pump, it's there to push with pressure, or to pressurize the fuel lines to prevent vapor lock and pump cavitation.
The output pressure of the fuel pump, by the nature and general definition of a pump, is higher than the inlet, which may have little or no pressure at all. The pump is there to push fuel to a new destination. Some pumps pull, most push.
The reason for the pump is the determining factor, as well as it's location in the system.
Suction pumps, on the other hand, serve the primary purpose of pulling fluid from one location and then providing motive force to get it some place else. Their primary purpose is generally to draw fluid from a source, as opposed to supplying it under pressure to another source. In a typical oil system, the engine driven oil pump serves as a pressure pump to force oil under pressure to the various bearings, ports, and galleys in the engine. Scavenge pumps retrieve this oil, sucking or pulling it from collection points, and returning it to supply the pressure pump via resorvoirs, oil coolers, and other interim stages or devices.
Hydraulic pumps push fluid under pressure to accumulators, actuators, and hydraulic lines, accessories, etc. The purpose of the pump is not to pull fluid through the system, and system customer functions are not actuated by fluid being pulled through the system. These are actuated by fluid being pushed through the system under pressure, typically either 1,500 lbs or 3,000 lbs.
Weather the system pulls or pushes fluid, and pumps do both, is important to it's proper operation, and the understanding thereof.
I hope you feel better after writing all that "blah, blah, blah" in order to showcase a moot point.
It's a critical point, the knowledge and understanding of which may save your life some day. It did mine.
Then again, I can only assume that you're the PFM kind of guy, and that's the extent of your desire to understand the systems of the equipment you fly.
StrykerFL said:
Perhaps the engine driven fuel pump on most low wing single engine airplanes does not have enough suction to pull from both tanks.
Whoa, not so fast there. It require less effort to feed from 2 tanks at once compared to one tank, assuming the tubing has the same diameter.
Take one of those little plastic coffee stirrers that's like a small straw. and suck some water through it. Now take two and suck water through both at the same time. Which will be easier and quicker to suck up a mouthful of water? one straw or two?
I'm not about to get into a pissing match, but good ASSumption. Yeah, after restoring a car, working on tractors all the time growing up, and having an in-depth knowledge of aircraft systems I've been led to the conclusion of PFM. Riiiiight. Go back to turning some more nuts on your Polish Camel.
