Marmaduke McPug
Active member
- Jun 13, 2002
Marmaduke McPug said:I was mainly looking for technical info on the engine such as type and makeup of the compressor and turbine sections, accessory section and bleed points.
Burner can type; igniter type and associated temps, as well as the temp rise chart along the compression path.
I was also interested if there was a full cut away of the unit that showed the flow thru and any detail on the type and location of the attach points.
Mainly looking for specifics on this engine and do you know if any, the differences between the –2B and the –5, found on the falcons?
Mike
