saviboy said:hi i just made a ferry flight for my flight school. i did the flight with anothre friend instructor. can somebody tell me how we could log the two legs in both our logbooks?
thanks
thanks
You may wish to clarify the above--the ACTING PIC (the one who filed the flight plan if IFR) does not automatically get to LOG PIC by virtue of being the one responsible for the flight nor the one who filed the IFR FP. I trust you know the distinction, but perhap the post should be clarify for other readers.paulsalem said:Both of you can log PIC:
The one who is Pilot-in-Command can log PIC. (the guy who filed the flt plan if its IFR)
If the other guy was sole minipulator of the controls, he also can log PIC.
Or one can log PIC and the other can log PIC & Dual given.
I am saying that in some cases, simply ACTING PIC does not give you the right to LOG PIC. Logging PIC is governed wholly by Part 61.51(e). That's it.paulsalem said:You are saying that if you are actcing as the Pilot in command of an aircraft, but not flying it, then you can not log PIC?
Part 61.51
(e) Logging pilot-in-command flight time. (1) A recreational, private, or commercial pilot may log pilot-in- command time only for that flight time during which that person—
(i) Is the sole manipulator of the controls of an aircraft for which the pilot is rated;
(ii) Is the sole occupant of the aircraft; or
(iii) Except for a recreational pilot, is acting as pilot in command of an aircraft on which more than one pilot is required under the type certification of the aircraft or the regulations under which the flight is conducted.
(2) An airline transport pilot may log as pilot-in-command time all of the flight time while acting as pilot-in-command of an operation requiring an airline transport pilot certificate.
(3) An authorized instructor may log as pilot-in-command time all flight time while acting as an authorized instructor.
(4) A student pilot may log pilot-in-command time only when the student pilot—
(i) Is the sole occupant of the aircraft or is performing the duties of pilot of command of an airship requiring more than one pilot flight crewmember;
(ii) Has a current solo flight endorsement as required under §61.87 of this part; and
(iii) Is undergoing training for a pilot certificate or rating.
As you can see, the first way we can LOG PIC is if we are the sole manipulator of the controls of an aircraft for which we are rated. "Rated" in this case means what is printed on your license--it does not require any endorsements, etc.Part 61.51
In this case, the safety pilot is a required crew member per the regulations.Part 91.109
(b) No person may operate a civil aircraft in simulated instrument flight unless—
(1) The other control seat is occupied by a safety pilot who possesses at least a private pilot certificate with category and class ratings appropriate to the aircraft being flown.
