Logging Long Haul SIC/IO Time
jumppilot
Something in a box
I tried to search, but no luck on a substantial answer...
I've heard many different answers for this:
If I am a required crewmember (not CA) of a 3 member crew (CA, FO, IO), how do I log the time?
I'm under the impression I log it all as SIC since I'm a required crewmember (ie: the flight doesn't go without me), and that is the consensus among my peers.
A 10 hour flight to Europe, I log it all as SIC, regardless if I'm the designated FO or IO, or in the seat. With that said, I don't log actual or approaches unless I'm flying.
Thoughts?
FWIW, I log all my time as SIC... sure I'm PIC typed.. but the PIC, even if he's in bed, is still the signed PIC on the plane. I also have no problem logging the time while I'm in the bunk.. I'm still required crew, and on duty.
That's my thought exactly.
I don't log PIC time, since we learned since day one that a CA can log PIC even when he is sleeping.
It depends on the flight rules. If you are flying part 121 rules you can't log PIC time unless you sign for the bird.
Hey fedora... how did recurrent go? Are you a still PIC? ;)
Why? You expecting me to bust or something?
Still PIC this week. Recurrent starts Tuesday so a little while longer to enjoy my left seat eh?
Na.. just busting on ya.. sitting here with GM in Shanghai drinking our 6th cup of coffee and board, so what else is there to do?
Thoughts?
Aren't you actually only required for that portion beyond 8 hours?
We log 2/3 of the flight time when acting as an RFO (IO, IRO) with a 3 member crew and 1/2 of the block when acting as part of a 4 member crew. Apparently our POI/FSDO has decided that is what is acceptable. Of course if you ask two different Feds, you're likely to get two different answers.
Thoughts?
§ 121.507 Flight time limitations: Three pilot crews: airplanes.
top (a) No certificate holder conducting supplemental operations may schedule a pilot—
(1) For flight deck duty in an airplane that has a crew of three pilots for more than eight hours in any 24 consecutive hours; or
(2) To be aloft in an airplane that has a crew of three pilot for more than 12 hours in any 24 consecutive hours.
(b) No pilot of an airplane that has a crew of three pilots may be on duty for more than 18 hours in any 24 consecutive hours.
[Doc. No. 6258, 29 FR 19218, Dec. 31, 1964; 30 FR 3639, Mar. 19, 1965, as amended by Amdt. 121–253, 61 FR 2613, Jan. 26, 1996]
§ 121.509 Flight time limitations: Four pilot crews: airplanes.
(1) For flight deck duty in an airplane that has a crew of four pilots for more than eight hours in any 24 consecutive hours; or
(2) To be aloft in an airplane that has a crew of four pilots for more than 16 hours in any 24 consecutive hours.
(b) No pilot of an airplane that has a crew of four pilots may be on duty for more than 20 hours in any 24 consecutive hours.
In a nutshell:
You can only be on "flight deck duty" for 8 hours in any 24 consecutive hours. Using a relief officer allows you to be "aloft in an airplane" for 12 or 16 hours, depending on crew of 3 or 4 pilots. Logging 10 hours in a 24 hour period is OK if you are flying under Part 91 (or Part 135 2-pilot crew) but not under Part121.
Do you have a reference for this? My Part 61 makes no mention of Part 121 vs. any other part in regard to logging pilot time.
In a nutshell:
So how can the CA log PIC for the whole flight? Remember, the CA can log PIC even when he is sleeping!
I also believe that while the flight deck crewmemember isn't schedule for more than 8 hours (hence having a relief pilot), it doesn't mean he can't log the time.
guys, you're all mixing up what the FAR's say vs what the airlines say..
the FAR's indeed say 8 hours in a 24 hour period, and there is no 121 vs 91 or 135 def.. BUT.. even though under the FAR's the person who is the "Sole manipulator of the controls" can "legally" log PIC.. it is the guy who is sighed for the airplane that is ALWAYS the PIC as far as your next airline interview..
Fedora. I'm curious, when two CA's go out on a heavy crew.. who is PIC? Does it indeed alternate? or is the senior CA always assigned as PIC?
The same way a ships Captain takes the hit when something happens and he is in his cabin asleep. The Captain of record is responsible for the entire flight and can therefore log it.
As far as logging flight time when you aren't on flight deck duty, do you also log flight time when you deadhead? That's what you are basically doing; deadheading aboard a flight to act as a pilot on flight deck duty for some portion of the flight. We did the same thing under Part 135 to stretch our range. Put two qualified pilots on board operating as single pilots. One would fly for 6+ hours, we would stop for fuel, and then the other would fly for 6+ hours. We were both on duty, and therefore limited to 14 hours, but we could get beyond the 8-hour single pilot/10-hour two pilot flight time rule.
Sounds like you have already rationalized how you plan on logging flight time so why ask for a regulatory reference? Do whatever you want. It only matters when you have to explain your actions to "the man".
Baron,
1) You are not deadheading when you are assigned to the flight. If was was assigned a DH only to pick up the turn at the other end, I would not log it. However, if the flight can not leave without 3+ crewmembers, are you really deadheading?
Again, I'm not talking about what happens in the single-pilot 135 world, but rather 121 long haul where 3 crewmmembers are indeed required crew.
2) We are not discussing single-pilot 135 operations. Being assigned an FO or IO, you are indeed assigned flight deck duties. After all, all crewmembers are on the release as required crew...I've never seen a flight where DH'ders in the back were listed on the release.
Your 135 logic is flawed. "Stop for gas and the other guy flies the next leg."
I'm talking about the same leg.
We occasionally fly double crew and I only log the time I actually sit in the seat.(I'm an Fo) Flight time is not a big deal a few hours here or there anyway so I don't want to push it, especially if it is questioned in a future interview.
