Logging Instrument Time
UA-RESURRECTED
Does this mean I failed?
Sometimes you hear of people saying they've got a certain amount of "actual" instrument time, as opposed to "simulated", as I understand it.
So, if you are flying IFR, and then suddenly fly into VFR conditions, you must record this transition and make the appropriate logbook entries??? What if you're continuously flying in and out of IFR conditions, you have to keep track of all these changes?
How does this work when logging instrument time?
VSI9k+ said:
Just try to keep a count of how long you didnt have any reference to the ground. After the flight make a note of it...and then log it in the approiate colum in your log book. If you are IMC for 6 minutes, out of IMC for 6 and back in IMC for 6 minutes...you have .2 IMC but .3 total.
Okay I see what you're saying. Thanks.
One more thing. This is dependent on ground reference? If you're flying in basically clear skies above an overcast layer, you can log that as instrument time?
VSI9k+ said:
Ive heard people argue it both ways. Id just stick to logging the time that you have you head in the clouds and not worry about the reference to ground thing.
In that case you would still have a horizon, so you should not be logging it as IMC.
[FONT=&quot]I have always been unsure about logging actual as well... say it is a very dark night, you are on an IFR flight plan, there is no horizon, no towns, nothing to reference by except your instruments? Is that actual? How about if you are on top of the clouds and they have vertical development and therefore you don’t have a true horizon? Can you log that as well? I have just always logged time when I am in the clouds….[/FONT]
UA-RESURRECTED said:
Okay I see what you're saying. Thanks. One more thing. This is dependent on ground reference? If you're flying in basically clear skies above an overcast layer, you can log that as instrument time?
No, very difinately not. It's no outside reference, not no ground reference. If you are in clear skies above an overcast you have a wealth of outside references which make it very easy to control the airplane. it's quite possible to fly under those conditions without looking at flght instruments. remember, the regulation is: "...solely by reference to instruments....."
not:
".........without ground reference ........"
Say you´re flying over a large body of water at night. It´s CAVU- not a cloud in the sky. But it´s absolutely dark outside- no moon. Even though technically you´re in VFR conditions, because you can´t distinguish the horizon (nor any reference to the ground) that time would be considered instrument. I´ve had this over the ocean, over the Amazon (NOTHING, not a SPECK of light on the ground for HOURS) and even up in places like northern Wisconsin. If you have to stare at your AI to keep the plane straight and level, it´s instrument time.
I wouldn´t get too anal about the preciseness of your IMC time as well- I´ve yet to hear anyone say- ´Sorry, bud, you spent 14 minutes in the clouds, not 18!´ Just make an approximation. You don´t need to keep track on a sheet- 11:20- IMC, 11:23- VMC, 11:30-IMC, 11:35-VMC... (I´ve seen this done) a close approxamization will do just fine.
IMC=Instrument Meteorological Conditions
To me, that means in the clouds. The night over water, dark areas, undercast, etc...doesn't count toward actual instrument. Atleast that's the way I have always looked at it. My $.02.
IMC considers both clouds =and= visibility.
There's a famous FAA Legal Opinion out there that authorizes logging actual instrument time on a moonless light over water (posted below).
The definition of "actual" ultimately comes down to a very practical one: did you need the instruments to keep the airplane upright because of cloud and/or visibility conditions outside the airplane?
November 7, 1984
Mr. Joseph P. Carr
Dear Mr. Carr:
This is in response to your letter asking questions about instrument flight time.
First, you ask for an interpretation of Section 61.51(c)(4) of the Federal Aviation Regulations (FAR) regarding the logging of instrument flight time. You ask whether, for instance, a flight over the ocean on a moonless night without a discernible horizon could be logged as actual instrument flight time.
[unrelated portion snipped]
As you know, Section 61.51(c)(4) provides rules for the logging of instrument flight time which may be used to meet the requirements of a certificate or rating, or to meet the recent flight experience requirements of Part 61. That section provides in part, that a pilot may log as instrument flight time only that time during which he or she operates the aircraft solely by reference to instruments, under actual (instrument meteorological conditions (imc)) or simulated instrument flight conditions. "Simulated" instrument conditions occur when the pilot's vision outside of the aircraft is intentionally restricted, such as by a hood or goggles. "Actual" instrument flight conditions occur when some outside conditions make it necessary for the pilot to use the aircraft instruments in order to maintain adequate control over the aircraft. Typically, these conditions involve adverse weather conditions.
To answer your first question, actual instrument conditions may occur in the case you described a moonless night over the ocean with no discernible horizon, if use of the instruments is necessary to maintain adequate control over the aircraft. The determination as to whether flight by reference to instruments is necessary is somewhat subjective and based in part on the sound judgment of the pilot. Note that, under Section 61.51(b)(3), the pilot must log the conditions of the flight. The log should include the reasons for determining that the flight was under actual instrument conditions in case the pilot later would be called on to prove that the actual instrument flight time logged was legitimate.
Sincerely,
/s/
John H. Cassady
Assistant Chief counsel
