Logbook
Secret Squirrel
I found a mistake way back in my logbook. It would not have effected any of my ratings/legal issues but it is a pretty glaring mistake. Should I just adjust my total where I am or should I get the logbook green out and correct all pages? Which would look better or does it make a difference.
SS
Adjust the total where you are. Make an entry of "Correction from xx/xx/xxxx (date)", then adjust the applicable columns as needed, either by plus numbers or <0.0> (negative) numbers, then remember to apply the changes when you total up the page. Looks professional that you corrected the mistake; no one has ever questioned mine during an interview. :D
Re: Re: Logbook
Ditto on this...
Just note the date and the correction, and if possible the reason for it.
I highly doubt anyone has a log book with thousands of hours in it without a single mistake, you're just showing that you're honest about it. :)
Re: Re: Re: Logbook
Not quite thousands, but I just started a new logbook. Had three flights to enter and mad a mistake that required me to cross out the very first entry! :rolleyes:
