logbook pro sync to pda?
tathepilot
If I have logbook pro installed on my computer, can I sync my pda with it?
For example if I'm out flying can I make entries on my pda, and than when I get home sync up the two ?
You can do it, but you will have to buy the Palm or Pocket PC Companion from Logbook Pro for about $30.
Just a heads up...
if you get the PDA Companion the only things you can do with it are log your times while away from your computer and look at some statisitcal data based on your last sync. You cannot manipulate the data like you can on the PC with the analyzer. When you log your time in the PDA Companion it does not update the stats on your PDA until you sync with your computer.
I still like the PDA Companion and use it every day, but wish it had the ability to do some of the things the PC version could do.
srj
