ultrarunner
- Nov 26, 2001
Ok, so preliminary flight tests have been conducted. But Lear 60 operators that are even remotely considering this baggage locker need to UNITE!
1. Ball-park figures are somewhere approaching $250,000
2. It's going to be significantly larger than that of the units on the 30 series....(not a good thing for APU airplanes with an already aft-CG.
3. Initial reports indicate there will be NO change in ZFW or MTOGW.
So, think about this for a minute....
An EOW equipped 60 with an APU has a BOW north of 15,000 lbs. This baggage pod I suspect will easily add an additional 100 to 200 lbs of "dead weight" to the BOW.
What good is the ability to carry more crapolo if we're gonna gross out even sooner, in addtion to going out the rear-end. Since you know darn well, the same number of our passengers are gonna show up with more STUFF, since they just spend a quarter million on the baggage pod!
So, I propose that this POS baggage pod will score some big points IF:
1. We get a NET-MINIMUM increase in MTOGW of 500 lbs. Period. NOT negotiable.
2. A corresponding 500 lb increase in MZFW.
Anything less coming from a company like Raisbeck would be an incredible disappointment.
Carry on....
Carry on....
