Here is some info I copied from the DOT in Michigan.
(7) A person shall not operate an aircraft in a careless or reckless manner so as to endanger, or be likely to
endanger, the life or property of another. Other than at a licensed or approved landing area, a person shall not
fly an aircraft less than 25 feet (7.6 meters) above the ground at the field boundary, or closer than 25 feet (7.6
meters) to any object or structure while landing or taking off.
259.80d Landing aircraft.
Sec. 80d. (1) An aircraft shall not land, except in an emergency, on private property, other than upon
recognized landing areas, unless express permission is secured from the owner or lessee.
(2) A person shall not land an aircraft on a public highway, except in an emergency. A person shall not
operate an aircraft on a public highway unless traffic is controlled by law enforcement officials.
Lighter-than-air and emergency evacuation aircraft may take off and land on any public highway with
prearranged traffic control.
259.89 Private use landing areas.
Sec. 89. Sections 86 and 87a do not apply to landing areas designated and operated for private use if
commercial operations are not performed on the landing areas. A landing area for private use shall not be
established, without commission approval, within 5 nautical miles of a public use facility certified by the
commission or that would violate section 87.
And if you do it anyway, here is the fine and punishment....
259.180 Reckless operation of aircraft as misdemeanor; penalty.
Sec. 180. A person who operates any aircraft within the airspace over, above, and upon the lands and
waters of the state, carelessly and heedlessly in willful or wanton disregard of the rights or safety of others, or
without due caution and circumspection and in a manner so as to endanger or be likely to endanger any person
or property, is guilty of a misdemeanor punishable by imprisonment for not more than 90 days, a fine of not
more than $500.00, or community service of not more than 30 days, or any combination of these penalties.
