9GClub
- Dec 5, 2004
Hi guys,
I'm new on flightinfo.com and I thought I'd get down to business by asking some pesky questions right off the bat......
1.) Why are the four-wheel main bogies (just the wheel trucks-- I'm not talking about the vertical struts) on different aircraft cocked at different angles when they're extended? For example, they're cocked slightly "nose-up" on the B757 and nose-down on the -67. Also, the outboard (wing) trucks on the -47 are cocked up around 70 degrees to the horizontal, whereas the trucks on the L-1011 appear to be perpendicular (0 degrees) to the strut. I'd be surprised if it was arbitrary, especially considering the complexities of modern gear design (for example, the B773 main trucks lock perpendicular to the struts on rotation in order to kick the fulcrum back a few feet for tail-strike avoidance).
2.) On the MD-80 class of jets, I've noticed a small "platform" attached to the nosegear...... it's fairly prominent and can been seen clearly right behind the nose tires in most photos with the gear down. It's not a "mudflap" or anything goofy like that is it? Convenient stepstool for prospective stowaways maybe..... I'm out of ideas......
3.) Is there a "standard" tyre pressure (notice how I'm deftly switching back and forth between the American and English spellings of "tire" in order to appease any British brethren) for commercial jets? If not, how about a tire pressure "window"..... I'm sure it's modified according to aircraft type, load, surface conditions, etc., but are there any generalizations that can be made? For example, I read somewhere that the USN uses 200 psi for land ops and 300 psi for carrier ops with its Hornets.
Thanks in advance for any insights you can provide. I look forward to learning from y'all.
