KSMO crash
Thrust reverser failure? Debris on the runway prior to the jet veering off into the hangar.
This airplane would have had attenuators as its a "straight" CJ2, but something went WAY wrong not involving the little flappy thingies on the back of the engines...
I talked with someone who knows people on the Santa Monica Airport Commission this morning. The number one theory is that the pilot was high, long and fast and tried to land when he should have aborted breaking off one of the main gears and then the plane veered off the runway and impacted the hangar. He said its speculatory, but is the number one theory presently.
Or it could have been a pilot with inadequate experience flying a high performance aircraft that got away from him. It is easy to Monday morning quarterback, but if he was indeed high, fast and long, then a go round was really the only option. An experienced pilot may have been able to semi safely salvage this situation. I hope the CEO wasn't the sole pilot on the aircraft! The NTSB will have a field day with the findings, causes and recommendations on the final accident report.
Not saying the theory is wrong, but how hard do you have to impact to break off a main leg on a CJ? It's just not something that happens often enough to induce a number one theory very often. If that's what happened... Yikes.
Interesting
On-scene examination of the wreckage and runway revealed that there was no airplane debris on the runway. The three landing gear tires were inflated and exhibited no unusual wear patterns. The Federal Aviation Administration (FAA) control tower local controller reported that the pilot did not express over the radio any problems prior to or during the landing.
