King Air 90 ELT Arm?
Actually, it's not a button but a CB...but if you pull off the battery cover, you will see a 1 amp CB. This CB removes power from the Battery Switch on the flight deck.
Oh, I got a bunch of these :)
Lets see, there was another easter egg that I'm trying to rememeber....
Oh, Loss of AC power, and switching to the other INV has no effect...
how can you restore AC power?
I don't believe that's in the checklist either.
Ultra is correct on all the KAs I have flown also. Switch in the aft position is ARM. Most should have a placard outside the little door. I believe that you can order it from Rytheon, probably cheap...NOT.
