Keep It Going
it has not been tested on artificial skin colors. Prior to using this product, you should first test it in an inconspicuous area to determine if it will leave an undesirable tint or result in blotching. If the teated area produces desirable results, you may then ...
jaywc7 said:
the land of Michael Jackson and Jessica Simpson (you know - Pennsyltucky)...
lewis u pilot u messed up the thread..j/k
Where they got married and became Michael Simpson and Jessica Jackson. When asked why they didn't go with the traditional last names Michael replied in a high grab'in ball$ voice "I always wanted to be white". And Jessica looked at the reporter and said "I always wanted to be black...check out my ass". Then the both of them busted into a duet singing... it doesn't matter if your black or white just as long as you......
side note: Anyone who diverts from the thread is now called a cross sticher (CS, x-stich, x-sticher or any other acronym that comes to mind) back to work.
causing him to spend more time on........
( had to give mini time with the olsen twins)
So Jessica picks herself up, and manages to get away from Tony. She turns a corner into a dark alley, and to her amazement, there is minitour and michael bolton, and they're about to
