I'm flying a Beechjet and constantly have a discussion on what to put in the suffix code. The aircraft is RVSM cerified and it's equipped with an FMS with DME/DME updating. It also has a GPS, however we are unable to do Type B arrivals and departures (RNP stars and dps). Would you use /K or /L? Thanks
NO DME
No transponder
Transponder with no Mode C
Transponder with Mode C
DME
No transponder
TACAN ONLY
No transponder
AREA NAVIGATION (RNAV)
LORAN, VOR/DME, or INS with no transponder
LORAN, VOR/DME, or INS, transponder with no Mode C
LORAN, VOR/DME, or INS, transponder with Mode C
ADVANCED RNAV WITH TRANSPONDER AND MODE C (If an aircraft is unable to operate with a transponder and/or Mode C, it will revert to the appropriate code listed above under Area Navigation.)
Flight Management System (FMS) with DME/DME and IRU position updating
Flight Management System (FMS) with DME/DME position updatingGlobal Navigation Satellite System (GNSS), including GPS or WAAS, with enroute and terminal capability.
Required Navigational Performance. The aircraft meets the RNP type prescribed for the route segment(s), route(s) and/or area concerned.
Reduced Vertical Separation Minimum (RVSM). Prior to conducting RVSM operations within the U.S., the operator must obtain authorization from the FAA or from the responsible authority, as appropriate.
/E with RVSM
/F with RVSM
/G with RVSM
/R with RVSM
RVSM
Suffix
Equipment Capability
/X
/T
/U
/D
/B
/A
/M
/N
/P
/Y
/C
/I
/E
/F
/G
/R
/J
/K
/L
/Q
/W
