chperplt
Registered User
- Nov 25, 2001
That sounds like one or two...or five...of my relationships.....mzaharis said:Squeezed to 145 PSI (3.458 psi std atmosphere at FL350*42 pressure ratio for a Trent) while banged through a labyrinth/"cuisinart" of fan and compressor blades, heated to thousands of degrees, and banged through another labyrinth/"cuisinart" of turbine blades, only to be expelled into -60 degree air.
Essentially, that's the same sequence for the reciprocating engine, too.Birdstrike said:I'll always remember the way I was taught the sequence....suck, squeeze, bang, and blow.
Same sequence for a great date too.UnAnswerd said:Essentially, that's the same sequence for the reciprocating engine, too.
