Jetblue pilots begin organization drive...
Occam, you should consider a career in writing, if you haven't already done so.
poor pay? next time you make an ignorant statement, take the time to compare our airbus rates with the rates of your "brothers" at united, usair, and northwest. (dont forget to add the time and a half after 70 hours.)
thanks for the suggestion. ill go back to clean the cabin when your done bending over. (oh, i forgot, there is nothing you or ALPA can do about it, but be upset)
I see you like to compare your rates to those of bankrupt airlines or recently bankrupt airlines. However you conveniently forgot to compare your rates to another bankrupt carrier, DAL. We fly similar gauge equipment? Why don't you compare our 737-800 rates with your A320 rates. We're in bankruptcy and according to you we've bent over. Surely you must have a higher rate. I didn't think so.
Get back to cleaning the cabin.
What's wrong with ALPA is easy. The warts are right there, on the end of it's nose. They're an easy target. So easy, the disgruntled pilots looking for someone to blame attack ALPA like Rush Limbaugh goes at nachos and narcotics. I think that's why Rez and few others (like me) speak up to defend ALPA.
There is plenty of ALPA bashing on these threads, but I just wanted to hear some criticism coming from ALPAs two biggest cheerleaders on these boards... and you have done that. As I said earlier, it's difficult to find credibility in someone or something that fails to recognize their own faults.
Thanks for your informative and candid posts.
You've hit on an interesting issue. I think pilots that run for ALPA office don't do it to change their company...they do it to change their union.
I know I did.
100% of the ALPA officers and reps I've known (many!) jumped into it in a effort to "fix" the faults they perceived within ALPA. None of them got involved to "raise the pay rates on the 757!". They did it to change the way ALPA tried to get the pay rates raised.
The average pilot doesn't believe he is.
ALPA is run by pilots. It's our biggest strength, and our most vexing weakness. It helps us because pilots are natural skeptics and dyed-in-the-wool pragmatists. In negotiations or representation, pilots constantly play "what if?" and think of the worst case scenario.
It also hurts us because we need information to assuage our skepticism, and I don't think ALPA puts enough emphasis on communications with the membership, so 66,000 skeptics ("pilots") are utterly convinced that ALPA isn't trying. The responsibility for that communications rests with the local reps and the MEC's...not in Herndon. ALPA National should focus on keeping the resources in fighting trim, pushing our issues on Capitol Hill, and providing strategic planning (eg: the idea of syncing all contracts nation-wide to gain leverage).
Once a pilot gets neck-deep in ALPA work, they concentrate on accomplishing the mission, and tend to blow off communications with the membership. That's because pilots are goal-oriented doers (if we weren't, we wouldn't have gotten through all the tests, checkrides, physicals, interviews, etc required to get here). Telling others what you're doing while you're focused on actually doing it is tough, and very few pilots I've known can pull it off.
BIG weakness!
Still better than the alternative...
2. Another problem:
Timing. Want leverage? Have every ALPA contract in the country amendable at the same time. Items such as Brand Scope require massive amounts of leverage. The type of leverage we would have if all of us were standing on the lever at the same time. Our CEO's are amoral twerps who don't always use what we give them to the benefit of the profession. Exhibit A: Delta pilot cuts led to SimpliFares. (I'm not picking on DAL pilots here. There's plenty of buffoonery to go around! Anybody seen my Compass?)
To get our contracts sync'd up, every pilot group would have to make Term their #1 or #2 issue. It will also require National ALPA to get more involved at each property. Y'all ready for that? Do that one thing and we end the whipsawing and the ratcheting (see also: "Race to the bottom").
That's about the biggest single point I've agreed with you on in a long time...
The question is how do you force the issue when it comes strike time?
With the Pres able to order any pilot group back to work, what do you think he'd do if the majority of the airlines were facing a shutdown at the same time?
Striking alone we have only a 50/50 chance of being left alone. Striking in those kind of numbers would make the public go SCREAMING to their elected representatives and the white house would be forced to act. What do you plan to do then? Illegally strike anyway per the ATC guys? Worked out really well for them, didn't it?
The BIGGEST fault of ALPA is lack of follow-through. Every single time it comes down to brass tacks, the union pushes its members to sign in a crappy P.O.S. contract that doesn't even come CLOSE to meeting the Wilson Polling numbers.
If that's what you call "expectation management", then indeed, ALPA needs to do a better job. Don't beat the drum to get your members all riled up about a 20% pay raise then come back with 8% and say "This is the best we could do."
No wonder people are p*ssed off. If you SAY you're going to need 20% or your pilots walk, then BY GOD, WALK AWAY when the company fails to meet that mark.
Until ALPA is actually prepared to follow through on their work stoppage claims (which they haven't done in YEARS) stop making those claims. Until then, management will continue their behavior, simply because it has NO penalty attached to it (an actual strike).
Most alpa reps I knew got into office because they were the only person that ran, and they wanted paid time-off to booze with the boys in DC and Miami. All were people who most likely got beat-up at the bike rack while growing up. Furthermore, the 4stripe they "earned" was the first position of responsibility they have had in their entire life. After their wife whooped thier a$$ at home, they could come to work, throw that 4th stipe around, run unopposed for office, win, waste our 2%, and hold an "elected" position. Lets face it, alpa is a joke and has no spine. It needs to be put to pasture just like the airplanes of its time.
Don't forget your ALPAPAC contrabution this year. lol. Carry the dems sign and vote republican.
Exhibit "B" ladies and gentlemen!
Some of these ALPA haters make me laugh. They talk out of their ass without any facts or understanding of how this union works. Especially the current/ex members. When was the last time you went to an alpa meeting? When was the last time you made a motion to change things at local/national level? (oh wait, thats hard to do when you don't go to the meetings) We are alpa, we have to participate to be effective. When you have 2-3% of the pilot group show up for meetings, how effective do you think we can be? Don't you think management has people hanging around the lobby checking out the attendance at meetings? Don't you think management sees the participation percentages for votes on contracts/etc.? When you have 70-75% of the members vote on something important, management sees that as 25% just dont give a rats ass to take the 25 sec to vote over the phone. Alpa is more than pay scales. Who is fighting cabbotage, foreign ownership on the hill?? (Not management or the non-union carriers) Who fought for tcas, gpws,egpws,crew bunks,min rest,fsap,aqp,etc.? Management? Non union carriers? Consider your 1.95% as an insurance policy for ALPA legal, aero medical. Ask what the dal crew got from alpa when their f/d failed and they didn't comply with atc and got violated. (apla fought the violation and got it nixed) Would your non-union pilot group have got the same conclusion? Would management have offered lawyers to help you out. Ask my co-worker how long he would have been out after cancer treatment without alpa medical if he had to do the foot work/ paper work with management/faa bs. Even other pilot unions use alpa resources. Don't get me wrong, ALPA has its weaknesses, inhouse and most notably the membership. We are all guilty of nonparticipation, that is our weakness and will probably be our downfall. We have to get rid of this finger pointing/i got mine screw everyone else attitude. If some of you guys (and you know who u are) participated half as much as you complain, we would be in pretty good shape. Next time you ask "what has alpa done for me", look in the mirror. Other than writing a check every month, what have you done to change/participate/volunteer for alpa? We need to stick together to strengthen our position, but to look at this board and all the hate, finger pointing,wishing doom and gloom on others, we may be too far gone.
See? There's hope for you yet! :laugh: Seriously, even my wife doesn't agree with me all the time...and we're still madly in love.
(Ok...that was kinda creepy)
Disagree. That's never an issue! If your pilot group has authorized a strike, and the reps vote to reject the final offer at the end of the Cooling Off Period, you strike. We did it in '98 and it wasn't a difficult decision. Comair pilots did it for 89-days in '01.
That's the "force". If management doesn't give you an acceptable offer, you take the legal recourse and wage an economic war with them via a strike.
Which President? I think our current President would intervene if a large number of pilot groups were to reach the end of a Cooling Off Period at the same time. To get there, the NMB would have to declare an impasse. The NMB is appointed by the President. That gives the man in the White House two bites at the apple when it comes to pushing airline unions to accept what management offers.
I think Bush allowed the Comair pilots to strike because Comair (and Delta) management told him they preferred to take the pilots on.
I guess I don't understand your questions. For a strike to work it has to be 1) legal 2) executed by 99% of the pilots.
If you're familiar with the way the polling is used, then you know it is most effective when it is used to establish priorities, as opposed to specific numbers. It's almost impossible in a large pilot group to reach consensus on a specific number, but it's often easy to establish a set of priorities that can be supported by the entire group.
And let me repeat: You will sign a "crappy" T.A. only when you believe the alternative is worse. If a majority of the pilots feel the T.A. is better than the alternative...it passes. If you have a better method for setting contracts than following the will of the pilot group, I'm all ears!
That's where the attention to communications is critical. Contract negotiations are seldom limited to just pay rates. Usually they include work rules, benefits, Scope, and other items. Is an 8% pay raise, with the Trip Hour Credit you want more acceptable than a 20% raise and a crappy THC? Most sections in a pilot contract are shoelaced with other sections. That's where the polling comes in. ALPA "openers" are seldom the final number in the T.A.. The same goes for management's openers. There is a lot of jockeying as both sides try to honor their priorities. ALPA's priorities are established by the rank-and-file, through our reps, in an open process. Management's priorities are set by soul-less druids, in Machavellian fashion, in a windowless dungeon where money trumps ethics.
Speaking as someone who has "followed-through" and gone on strike, I find your conclusion factually lacking. Plenty of pilot groups in the last few years HAVE been fully prepared to walk. But let me repeat: The strike must be legal. If a judge prevents your job action, you comply. To suggest otherwise is to start down a slippery slope.
Regardless of the outcome of the negotiating process, there are going to be pilots who will feel their expectations weren't honored. If those expectations are shared by a clear minority...too bad. If they are shared by most pilots, you put the wrong pilots in office. And THAT is something you have control over!
