dakotaHC8 said:Hello,
real curious what the expected date for the arrival of your new E-190's ais, when/where they might be placed into service. And is there any news on hiring for this new fleet type at JB...?
Any info would be greatly appreciated...
R
dakotaHC8 said:Thanks,
Curious if they have started actual training yet,in the YUL sim for anyone to be on the E-190 (check airman, instructors, so on). Also curious, will the jetBlue models be equipped with the heads up display...?
Also, a more generic jetBlue hiring question. Does the company place substanial weight upon a havng a type in the aircraft it operates vs. current right seat experience in those same aircraft.
The reason I ask is that I do have about 500 Hours in the EMB-170 verison of your new aircraft, but no type rating for it. (EMB-170 First Officer time only)
R
avoidingmyboss said:• 1000 hours in airplanes at or above 20,000 pounds (maximum takeoff weight) or 1000 hours in large turbojet airplanes (12,500 lbs or above)
I copied this over from jetBlues web site. So if I read this correct if you are flying a bizjet over 12,500 lbs but under 20,000 lbs you can now apply? Maybe I'm out of the loop but is this a recent change?
