Jet Blue Emergency Landy - KLGB
From an inside B6 source, it was the "aisle donkeys" (his words) that deployed the masks, not the flight crew.
Agreed you don't want to feed O2 to a fire. Nobrainer. However, the smoke came from an engine fire and due to an engine grenading. They was no cabin fire to feed.
The cabin crew still shouldn't have dropped them (manually, I'm told, with the PSU tool), but in this case it caused no harm.
I'm going to disagree with you a little. Adding the rubber jungle unnecessarily, added an obstacle and served as a distraction to the actual evac. If they were really on fire in the cabin that could've cost precious seconds.
They only had a few minutes to prepare for an evacuation. I don't know why they thought it was necessary to spend a good bit of that limited time messing around with masks. It didn't help and could easily have hurt. Didn't they have better things to do?
They don't understand that the o2 mask do nothing to save you from the smoke.
F/A's don't have the same system knowledge. 13 minutes from take off to touchdown, not a bunch of time to prep if you assume fire with all that smoke and you're worried about loss of life. Wait for the facts. I say great job folks.
Exactly my point. They went off-script to do something that couldn't help, could have hurt, and - worse - took much of their limited time away from their primary responsibilities. While they're busy making up their own procedure of releasing 50 PSU's manually with a key in a smoky and rapidly descending cabin, they're *not* preparing for an imminent, unplanned evacuation. Great job? We're so busy patting ourselves on the back that we forget that there's much here that didn't work well.
Turn off the engine bleed=No smoke in cabin. It's much easier to think when not in the heat of battle. Don't know if I would have thought of that in an emergency either.
It's part of the checklist. I'm sure they got to it, but you don't jump around all over the checklist to quickly get to the bleed. If a little smoke gets in, oh well.
Excellent point!
