In response to the silly and senseless ridicule this guy got (http://forums.flightinfo.com/showthread.php?t=71599) for actually using this forum for something meaningful and educational, I thought I would follow his lead and do the same. If you don't like it, tough $hit!
1) So, you are stuck down at 6,000ft 40 miles from your intended airport of landing, picking up moderate icing at a pretty good rate and needing to land. No VMC within the range of your fuel or warmer WX to climb into, so you are going to have to fly around in the ice. Well, your wing anti-ice (Bleed Air) just signed off on both engines. It's gone for good. For whatever reason, a freak of nature failed the valves shut. How can you heat up those wings enough to keep the ice off? Be specific about what you can use, and how to use it to determine that you are not picking up any ice and shedding whatever ice you had on your wings. (Clue: In doing this, you'll shed ice from the entire airframe, not just the wings)
2) You are at altitude (FL390) and still in the clouds. All of your Anti-ice works just fine, but you don't want to use it so you can keep your speed up. At what point (what determines or what conditions(s) must be present) for you to know that is ok to leave the Anti-Ice off and by doing so you will not pick up any ice. In other words, what condition must be present in order for you leave the ice off? Remember, you are in the clouds (visible moisture) and since you are higher than FL240 it's well below freezing.
Both of these questions are actually pretty simple, you just have to think about them a little bit. Some of you guys probably know the answer, so it might be good to let a couple of guys that don't know take a stab at it. Good luck guys.................
