After reading about how it will eventually happen to most pilots, I had a attitude indicator partially fail in IMC. I was skimming along the tops straight and level and glanced down at the AI and it showed a 12 deg. right bank. Luckily it was a broken layer so I could pop out and verify that I was in fact straight and level as well as comparing my DG and rate of turn indicator which were both showing straight flight. The vacuum gauge was right in the green, so I concluded the bearings or something in the AI was bad.
I asked and received a return to home base direct and a descent to get me out of the bottom of the cloud bases. It was a good test of trying to block out an instrument that you can't trust as I had to desend through 3000 feet of clouds. I didn't have time to cover it with anything (nor did I have any good covers handy). I will be buying some covers for instruments now.
This event inspired me to go up and shoot approaches with a safety pilot partial panel which is something I (and probably most) pilots do not pratice enough.
Keep practicing for the unexpected and fly safe!
