UA-RESURRECTED
Does this mean I failed?
- Nov 3, 2005
sleddriver71 said:Do it if you want to be a better pilot. You will learn what "seat of the pants" really means. I used to fly and instruct in a Cessna 120, that is when I really understood about using the rudders to keep it coordinated. I understood what adverse yaw was too. In that plane, if you tried to bank into a turn without using the rudder it would automatically yaw the wrong way while you banked and you would pretty much continue in an uncoordinated straight line. It was as McJohn put it a "humbling" experience. It was also the most rewarding flying I've ever done. I got my endorsement in a 150hp Super Cub. It was, to me, a lot easier to keep under control on the takeoff roll than the 120 which had 85hp. In the Super Cub if you ever got out of shape on the ground, all you had to do was add full power and you were airborne right now. The 120 was gutless and required you to drive it down the runway for quite some time before it gathered up the speed to liftoff. This, in my opinion, made the 120 a better tailwheel trainer, it just took more skill to stay out of trouble. If you want to do something challenging and really fun and become a far better stick and rudder, go find an "experienced" tailwheel instructor and get the endorsement.
Waldom said:If your primary flight instructor did his or her job correctly, it will make little difference to the student where the little wheel is located on the aircraft. By this I mean that the instructor required faultless flight control coordination, precise airspeed control, and tolerated absolutely no drift at touch down or anywhere else on the landing or takeoff roll.
While a tricycle landing gear allows you to be a sloppy pilot, your instructor may not have done the same. If this happy circumstance was the case, you don't need a tailwheel endorsement. If you suspect that your instructor was a bit lax or you don't maintain those standards yourself, get another instructor or make it a point to get comfortable in a conventional-gear aircraft.
VNugget said:Completely worthless. Much rather be rolling in plush leather luxury of a G-1000-equipped Cessna Skyhawk 172SP. Aww yeah! Who would want to waste their time in something obsolete like a taildragger? I bet they don't even have GPS.
No harder than a Cessna 210.(sa227) was a pretty difficult plane to land by dardar
dardar said:but the hardest was a piper tripacer with a tailwheel conversion.
