Amish RakeFight
Registered Loser
- Dec 28, 2005
Here's something I found on another board. It's credited to a poster by the name of "Crewdog" at airlinepilotforums.
Cont'd.
Being the best Captain you can be. Notes from a Crewdog.
Here are some scenarios myself and others have encountered during my 7 years as a Captain at Express on both the ATR and the ERJ. Some of these scenarios are "no-win", other times there are many different ways of solving the problem and arriving at a successful conclusion.
One thing I want to emphasize is that you should no longer worry about flying the airplane, doing the weight and balance, programming the FMS or getting tied down in details you can hand off to the FO. The Captain’s job is to MANAGE the aircraft, keep the big picture and make safe decisions. The crew, passengers, ATC, Dispatch, ramp and gate personnel are all responsible to the Captain. "The Pilot in Command of an aircraft is ultimately responsible for the safe conduct of the flight." (FAR 91.3)
But with that responsibility you also need to know how to use your resources for the best and safest outcome of the flight. Even if it means admitting you are wrong or that someone else has a better idea. Which is sometimes the hardest thing for a new Captain to do even if it is the best thing. It was for me sometimes.
As you run through these scenarios when you think "I’d say this or do that." I want you to do/say it aloud. You will realize that SAYING you would verbalize something and ACTUALLY verbalizing it are two different things. Now that you are done with the Sim portion of the training you need to move on to simulated interpersonal problems, which can sometimes be the hardest part of the job since there is no checklist to follow and the wrong words to the wrong person could get you in disciplinary trouble. Yes, every one of these things has happened to me or someone I know. None are made up.
Recommended/mandatory reading for new Captains:
Dr. Anthony Kern, LTC USAF; "Flight Discipline" and "Redefining Airmanship".
Ernest K. Gann; "Fate is the Hunter"
General Situations
-Great Captains are made not born: Why you should be including your FO in your planning/decision making.
-Customs in a foreign country pulls one of your crewmembers off into a side room for special questioning. What are your rights, what should you do?
-TSA is inappropriately wanding your female FA. What do you do? What are her rights?
-You are very close to departure and there is chaos in the jetway with many ground personnel all giving you conflicting information, getting in your FA’s way and wanting to close the MCD and pull the stairs/jetway for an on-time departure. What do you do?
-Gate agent pulls jetway/stairs from aircraft, leaving the Main Cabin Door open to the ramp.
-Scheduling argues with you about required rest on a reduced rest overnight.
-You arrive at the hotel after extensive delays for a reduced rest overnight. The hotel informs you they have sold your rooms and all they have are smoking rooms with couchbeds.
-You are put on the same floor as a wedding party/convention/group for a reduced rest overnight with a very early wakeup and a 12 hour day scheduled. You can’t sleep because of the noise in the hallway from people partying and running up/down the hall. What do you do?
Aircraft Problems
-Mx in other countries.
-At an outstation the station manager comes into the cockpit and says she is grounding the aircraft, it has a fuel leak. Upon inspection you see that the aircraft is being fueled and the "fuel leak" is just venting from the spark arrestor/overflow vent. You explain this to her and she states she has already called Contract Mx and the aircraft will not be allowed to move until they inspect the airplane.
-On takeoff just after getting airborne the #2 engine fire warning light illuminates then goes away. What do you do?
Weather Problems
-Dispatch says you don’t need the fuel, your gut says you do. If you add the fuel you’re going to have to bump people and or bags. Weather appears to be ok but….
-Same as above but you’re going to have to bump nonrevs, including commuting pilots.
-When would you perform a high speed abort on icy runway? What about if you have an engine failure with low ceilings in a snowstorm on an icy runway covered with anti-ice fluid with a crosswind in a place such as Halifax?
-Ugly weather day going to EWR. Dispatch lists LGA as your alternate, 8 minutes enroute, 400# of fuel. You know that if the weather is so bad in EWR everyone and their brother will be bailing to LGA and there is No Way you will make it there in 8 minutes with 400# of fuel. It’s going to be more like 30-45 minutes and you’re going to need 800-1,500# of fuel. If you want to list a more realistic alternate you’re going to have to bump passengers to get the fuel on board. What do you do?
-Ugly weather day. As you’re boarding a FA in uniform looks into the cockpit, and in a loud voice that draws the attention of every passenger within ten feet says "Now, you DO know how to fly in weather like this, right?" What if they are deadheading to an assignment? What if they are trying to go home?
-Ugly weather day with delay at outstation. While boarding a passengers draws the attention of everyone in the area by saying very loudly (trying to be funny): "Didn’t I see you at the bar during the break?"
-TSTMs ahead, you want to deviate. ATC says unable, opposite direction descending traffic. What do you do?
-Same scenario but the frequency is so clogged you cannot get your reply in. What do you do?
Cont'd.
