Interesting: No rudder needed at all???
UnAnswerd
Activity Terminated
So I went up for my second lesson, and was introduced to making turns. My instructor would position a movable marker on the heading indicator, and have me turn to the heading. We did so at a 30-degree bank. The airplane turned solely with the use of aileron deflection. No rudder was ever needed. I really didn't expect this. Is this typical???? You figure in a left turn the left aileron moves up, decreasing lift on that wing while simultaneously increasing lift on the right wing, resulting in a bank to the left. But you'd think the right wing would also be developing more drag, causing the plane to actually want to turn right. Nevertheless, no rudder was needed. Can somebody please help me understand this?
Any information would be greatly appreciated.
Most trainers require little or no rudder during left turns and a little rudder during right turns at cruise power settings.
To put it quite simply (perhaps too simply), rudder input is required to counteract adverse aileron yaw. Older aircraft designs (ie J-3s and 7AC Champs), frequently didn't employ yaw reducing techniques such as differential aileron throws and require much more rudder input as a result. More modern designs such as Piper's PA-28 series are so forgiving that some students never really learn "what their feet are for". Some aircraft, like the MU-2, use spoilers for roll control and consequently have minimal need for rudder input.
Lead Sled
As other pointed out, the rudders are for coordination- to overcome adverse aileron yaw. The airplane will turn with aileron only, but the turn will initially be uncoordinated.
We'll use a right turn as an example. If you look out the window at the nose carefully, you will see the nose drift slightly left as you begin the turn and then "catch up" with the rest of the airplane. It's that initial tendency to drift in the opposite direction that you are correcting with your feet
That "catching up" is part of the airplane's stability. It "wants" to fly coordinated. You can demonstrate the same phenomenon with rudder-only turns. From straight and level flight make a right turn using rudder only. The airplane will yaw to the right, but the airplane will eventually bank
No Rudder
And when you get to ILS approaches, you'll make heading changes of, say, two degrees, with rudder only...
If you ever fly a glider you definitely will have to use the rudder to make a turn. If you forget to the glider will remind you pretty quickly. Most airplanes are designed to not need a lot of rudder.
Or it could be that you have a lousy instructor and he is moving the rudder with his feet while you fly.
Horrible technique on his/her part. You might ask him if he is doing that.
No you wont! This is the stupidest thing I have ever heard taught by an instructor. Try doing that in a 757-300 with the passengers in the back moving 30 feet laterally when you yaw the plane about that axis. You'd have puke everywhere.
If you are off the localizer, make a normal turn a few degrees until you are back on and then turn back, applying any correction.
Using the rudder for small localizer corrections is lazy and no one should be teaching that.
Bad idea. It works OK with little airplanes, but as mmmdonut said, it's not a good idea once you get into larger aircraft.
Over the years, I've given many instrument competency checks and I've seen pilots try just about every imaginable way to track the localizer. (The wildest was a Cessna 310 jock who insisted on using differential power!) The secret is not to let the error get too big. Stop the error from getting worse, then correct back to where you want to be. With all respect to your instructor, I would have to question his technique for anything other than very minor corrections. Aircraft with flight directors and autopilots fly the localizer with the ailerons. All in all, it's probably the best way to accomplish the task.
Lead Sled
I know a very experienced DE who doesn't like it much in little airplanes either.
If we follow the common wisdom that the max angle of bank is the lesser of standard rate and the number of degrees to turn, those 2-3° turns aren't going to have much bank anyway. But, I was taught the rudder turn also, and my ability to hold the localizer with small corrections increased a lot when I started making even those small turns coordinated.
Rudder only is very lazy and is a substitute for learning to use corect technique.
To the original poster:
Here's an experiment to try next time you fly:
Slow to stall + 20 or so knots.
Try making turns with very large aileron deflections with and without rudder.
You wll see the difference, I asssure you.
Now, as to why you 'didn't need' rudder in your instructor's demo:
Adverse yaw is directly proportional to the amount of aileron deflection.
The stabiliing effect of the vertical stabilizer is enough to overcome most of it in a typical Cessna or Warrior/Archer. Also the higher the airspeed, the better the stabilizing effect. Try the experiment I described, and you wlill definitely see the need for rudder.
Poor rudder use is a big reason that many IFR students fall apart on the last 200' of an ILS. The uncoordinated 'aileron only' technique works really well until near the end when more precision is required.
One of the reasons for the 'rudder only' technique is that it IS easy to make small accurate heading changes this way, But is is sloppy, lazy technique.
Miniscule, but correct use of rudder has worked well to 'fix' ILSs for the many dozens of IFR students I have worked with.
Yep, that's what we were flying. My instructor did have me push rudder only. The plane yawed, but things were clearly uncoordinated by observing the inclometer.
I did. He had me turn the yoke and we make a turn. Since I was under the impression that you always had to use the rudder, I was surprised, and proceeded to ask him if he was applying any rudder. He said "no rudder". I'm sure I'll learn more about the rudder as I progress further into my training.
The rudder is actually only there to made up for a flaw in the design of alerons. Pick up a copy of stick and rudder. Amazing book. It dispells many aerodynamic myths.
It's not really that simple and there are other valid reasons for rudders than merely to compensate for adverse aileron yaw. Rudders come in pretty handy when you need to slip or when you're landing in x-winds.
Unanswerd...
I'm not about to second guess your instructor's method. Granted, it's not the way that I usually choose to teach turns, but he probably has his reasons. The last thing your CFI needs is to have a student that runs to a forum like this one every time he he tries to introduce a new concept. Relax, take a few deep breaths and get on with the program. I'm sure that he'll teach it properly. If he doesn't, this forum isn't the place to go to get things sorted out. If it ever comes to that, you'll simply need to find another instructor. Like I said, give it a bit of time.
Lead Sled
Rudder
Rudder & The ILS
I didn't say I do it or teach it. I said "you'll be...with rudder only". I do know at least one guy, a DPE, who teaches it and the heading change at issue when I flew with him was literally 1 or 2 degrees, during an ILS. He demo'd his rudder-only technique to me not too long ago. Hey, it was his show at the time. He did comment about "people in the back" (we didn't have any at the time; it was an 8-10 seater).
I just teach "small corrections" on the ILS. And have shot many to mins in actual w/pax on board. No puke yet. (The DPE's demo came after my own aileron-guided bracketing. It's just his "thing", apparently.)
The intended implication of my earlier post was that given Unanswerd's present tendencies toward aileron-only turns during relatively large heading changes, he might have a tendency toward rudder-only during very small heading changes, on a localizer, and there is at least one DPE encouraging rudder-only in heading changes of one or two degrees, on a localizer. Unanswerd's original post reminded of the DPE's presentation.
That would be true if you only flew airplanes with counter-rotating props, or pure jets. Even Turbo-fans have left-turning tendencies due to the size of the fan. In a single engine airplane, or a twin that doesn't have counter-rotating props, your feet will (should) move everytime you move the throttle(s).
edit: I guess I left out gliders...
My students sure don't seem to think that they need any rudder on the takeoff roll. I beg to differ with them.
-Goose
Rudder During Climb
I've trimmed it in during climbs to altitude in a TBM-700. Small price to pay, though...It also comes in handy in multis when one stops turning.
ive used the rudder technique during approaches and ive found that it works better. students usually over correct and ive heard this is a good way to get them to make small corrections.
do you really need a rudder with larger aircraft? i doubt a captain or first officer on a 737 thinks about adding right rudder during their take off roll.
i could be wrong
i could be wrong
Do you still get left turning tendencies with jet aircraft? That's really cool...I thought it was just prop aircraft...cool....
-mini
Rudder, Rudder, & More Rudder (Or Was It Less Rudder?)
Hey, how about V-1 cuts? Now, those are cool! At or above V-1, hold that rudder and wait for VR...
All this rudder talk, yaw'll take care, now!
But what about engine cuts at rotation?...or rotating a large aircraft with "take-off flaps" not set, and with heavy ice accumulation from the 30-minute wait at the take-off position, and trying to stagger out of ground effect?...that's when the lack of rudder control is so very evident by the excessive "waggle" on the "steering wheel".
Even in a big jet, in those conditions, adverse aileron yaw is the Killer.
...and so, you are well served by the instructor who imposes on you the active, aggressive use of the rudder during your early training.
The practice of using "rudder only" corrections translates to a higher skill of immediate rudder response for heading corrections in general. Rote monkey response. Then as we develop skill and control touch, we feed in in aileron as needed to keep it smooth.
Practicing rudder only pressures, lightly, smoothly, and immediately at the first peek of a dot from behind the needle, will keep the pressures so light that the passengers will not spill a drop.
If trained to do this from the very first, the touch will come from life-long practice, and the pilot will retain the "foot-rudder" skill which so often causes him to lose the immediately-required-rudder-situation on Take-Off or Landing.
-mini
You do in high-bypass turbo-fans, though it is much more subtle. The higher bypass the engine, the higher the percentage of thrust that is being produced by the fan. Fan blades have ascending/descending blade issues just like props do. On takeoff roll, most of the time you are correcting for the centerline with rudder (and nosewheel steering via the rudder pedals) because of the engines spooling up at different rates. However, it seems like nine times out of ten, your initial correction is with the right foot.
Speaking of P-factor topics (not to hijack the thread....)
Is there any reason that all props rotate the way they do? (clockwise from cockpit).....
I assume its just cause the first one was made that way so they continue but assuming they redesigned the airplane and engine and prop to account for this....would there be any forseeable advantage to building an airplane with a prop that rotates the other way?
I know they have this on seminoles to make it so there is no specific "critical engine".....Am I just hitting a rock against a wall with this one??? ;)
