Ok, I very much understand your point and agree with what has been said. that being stated, I am reading through the Part61 FAA FAQ posted from http://forums.flightinfo.com/showthread.php?t=51640
It seems to read that as long as the training isnt for a furtherance of a certificate or rating, this training is allowed assuming the CFI-I has a comm Multi w/ instrument. This would also preclude the 5 hours in type.
In the case of an IPC, the document says as long as you have 5 hours in type, CFII, and Commercial multi w/ instrument you are ok. I just see the discrepancy between that answer and the text of 61.195b1.
The excerpt I am talking about reads as follows:
I am not going to do anything that really requires me figuring this out for sure but I am just curious which it is....The FAR's seem straight forward but this interpretation FAQ is just confusing me more....Thanks for the replies.
QUESTION: What are the privileges held by a CFI - Instrument Airplane “only” (no single or multiengine rating) on his CFI with respect to instructing instrument procedures in a multi-engine airplane. He has multi-engine rating on his commercial certificate. Can he, while instructing instruments, simulate engine failure? Can he demonstrate VMC? Can he simulate engine failure during takeoff prior to 50% of VMC? Etc.
ANSWER: Ref. § 61.193(f) and § 61.195(f); Per § 61.193(f), a person who only holds a Flight Instructor-Instrument Airplane (CFII) rating is authorized within the limitations of that person's flight instructor certificate and ratings to give training and endorsements that are required for, and relate to an Instrument‑Airplane rating. And per § 61.195(f), in pertinent part, states a flight instructor may not give training required for the issuance of a certificate or rating in a multiengine airplane unless that flight instructor has at least 5 flight hours of pilot-in-command time in the specific make and model of multiengine airplane. These sections 61.193(f) and 61.195(f) are the only regulatory requirements that even remotely addresses your question.
Since training on the Vmc maneuver and procedure is not a task associated with the Instrument-Airplane rating, a person who only holds a Flight Instructor-Instrument Airplane (CFII) rating may not give the training required for that maneuver and procedure.
Since the training on the simulating engine failure during takeoff prior to 50% of Vmc is not a task associated with the Instrument-Airplane rating, a person who only holds a Flight Instructor-Instrument Airplane (CFII) rating may not give the training required for that maneuver and procedure.
However, there is no regulatory requirement in Part 61, other than § 61.193(f) and § 61.195(f) that apply. There is nothing that legally prohibits a person who only holds a Flight Instructor-Instrument Airplane (CFII) rating and has at least 5 flight hours of pilot-in-command time in the specific make and model of multiengine airplane per § 61.195(f) from giving the training required for the maneuver and procedure on “One engine inoperative during straight-and-level flight and turns (multiengine)” because the maneuver and procedure on “One engine inoperative during straight-and-level flight and turns (multiengine)” is a task associated with the Instrument‑Airplane rating.
Likewise, there is no regulatory requirement in Part 61, other than § 61.193(f) and § 61.195(f), that legally prohibits a person who only holds a Flight Instructor-Instrument Airplane (CFII) rating from giving the training required for the maneuver and procedure on “One engine inoperative—instrument approach (multiengine)” because the maneuver and procedure on “One engine inoperative—instrument approach (multiengine)” is a task associated with the Instrument‑Airplane rating.
Unfortunately, Part 61 and every other rule does not regulate judgment! I can't imagine an owner of an aircraft or an insurance company ever allowing rental of their multiengine airplane to a person who does not hold an airplane multiengine rating on his/her flight instructor certificate when that person intends to give training on engine inoperative maneuvers.
The following are the areas of operation and tasks that relate to an Instrument‑Airplane rating. A person who only holds a Flight Instructor-Instrument Airplane (CFII) rating may provide training on the following areas of operation and tasks that are associated with an Instrument-Airplane rating:
I. Preflight preparation
A. Weather information
B. Cross-country flight planning
II. Preflight procedures
A. Aircraft systems related to IFR operations
B. Aircraft flight instruments and navigation equipment
C. Instrument cockpit check
III. Air traffic control clearances and procedures
A. Air traffic control clearances
B. Compliance with departure, en route, and arrival procedures and clearances
C. Holding procedures
IV. Flight by reference to instruments
A. Straight-and-level flight
B. Change of airspeed
C. Constant airspeed climbs and descents
D. Rate climbs and descents
E. Timed turns to magnetic compass headings
F. Steep turns
G. Recovery from unusual flight attitudes
V. Navigation systems
Intercepting and tracking navigational systems and DME arcs
VI. Instrument approach procedures
A. Nonprecision instrument approach
B. Precision ILS instrument approach
C. Missed approach
D. Circling approach
E. Landing from a straight-in or circling approach
VII. Emergency operations
A. Loss of communications
B. One engine inoperative during straight-and-level flight and turns (multiengine)
C. One engine inoperative—instrument approach (multiengine)
D. Loss of gyro attitude and/or heading indicators
VIII. Postflight procedures
Checking instruments and equipment
{Q&A-457}
