Skippy22,
What do you mean by climbing to the missed approach altitude?  When executing a missed approach, you must remain at or above the applicable minimums for the approach being conducted, until the missed approach point.  At that point, the missed approach must be commenced.  You may climb before that point, but may not turn.
No requirement to climb above MDA/DH exists until the MAP, nor is there any requirement to stay at MDA or DH.  If one experiences a glideslope loss while operating below MDA for the localizer-only approach, one must at a minimum climb back up to the nonprecision minimums.  This being the case, and the approach having become destabliized, in most cases going missed is the wise action.
"Hey Is there a legal definition to what you can do if the GS fails.
Thats what we need written information telling us what we can and can't do. All we know is that if we go missed we cannot go missed till the MAP, so where does it say we can't revert to a LOC only approach?  I need proof, not technique. I have always taught to continue at LOC mins if above, if below then go missed.
Maybe someone out there has the TERPS guide?"
If the glide slope fails, you are still flying an ILS approach, sans glideslope.  You must use the applicable minimums, as specified in the proceedure.  This is basic.
You CAN go missed before the MAP; you just can't turn before the MAP, barring specific clearance to do so from ATC under specific circumstances.
This isn't technique.  It's basic instrument proceedure.  It doesn't require reference to TERPS.    You're not reverting to a LOC approach.  It's still an ILS approach.  Loss of glideslope doesn't change that.  You're flying the ILS without a glidesslope; you're flying the same proceedures, but need only select the appropriate minimums.
Sometimes multiple stepdown fixes or other special considerations may make continuation of the approach impractical, even with a prebriefing.  If you have the fuel, often it's best to come back and try it again.
You do have the option of continuing.  Your timing, the type of approach, the distance, the circumstances, and weather your fingers are crossed the right way make the difference.  Sometimes it's practical and appropriate to contineu, and other times it isn't.  In most cases, going missed approach is appropriate.
