See also AIM http://www2.faa.gov/ATPubs/AIM/Chap1/aim0101.html3-7-5. PRECISION APPROACH CRITICAL AREA
a. ILS critical area dimensions are described in FAAO 6750.16, Siting Criteria for Instrument Landing Systems. Aircraft and vehicle access to the ILS/MLS critical area must be controlled to ensure the integrity of ILS/MLS course signals whenever conditions are less than reported ceiling 800 feet or visibility less than 2 miles. Do not authorize vehicles/aircraft to operate in or over the critical area, except as specified in subpara a1, whenever an arriving aircraft is inside the ILS outer marker (OM) or the fix used in lieu of the OM unless the arriving aircraft has reported the runway in sight or is circling to land on another runway.
PHRASEOLOGY-
HOLD SHORT OF (runway) ILS/MLS CRITICAL AREA.
k. ILS Course Distortion
1. All pilots should be aware that disturbances to ILS localizer and glide slope courses may occur when surface vehicles or aircraft are operated near the localizer or glide slope antennas. Most ILS installations are subject to signal interference by either surface vehicles, aircraft or both. ILS CRITICAL AREAS are established near each localizer and glide slope antenna.
2. ATC issues control instructions to avoid interfering operations within ILS critical areas at controlled airports during the hours the Airport Traffic Control Tower (ATCT) is in operation as follows:
(a) Weather Conditions. Less than ceiling 800 feet and/or visibility 2 miles.
And if it's not Class D or higher?TR4A said:It is ATC responsibility to tell the pilots to hold short of the ILS critical area.
I predict that when it becomes the pilot's responsibility to keep track of the weather and PUBLISH THE ATIS, then it'll be the pilot's responsibility to know when the weather requires holding short of the ILS Hold line.umkay said:I asked the SLC tower last night and they said it's the PILOT'S responsibility to hold short of the ILS whenever wx is below 800 or 2. Go figure. Everyone else I've asked said tower or ground will issue the hold short instructions.
