ILS approaches and stepdowns
Ben Dover
This topic has been discussed before, but I still have two questions:
Here's the previous threads if you're interested:
http://forums.flightinfo.com/showthread.php?t=74454&highlight=glideslope+intercept+stepdown
http://forums.flightinfo.com/showthread.php?t=19298&highlight=glide+slope+intercept+stepdown
OK, so given the scenario where you are cleared to "maintain xxx thousand until established, cleared for the ILS XYZ approach." My questions are:
1. If you elect not to descend to charted stepdowns and simply intercept the glideslope and follow it down. And, assuming it's the true glideslope and not a false signal, while ON the glideslope you descend below one of these charted stepdowns. Are you in violation of any FARs, or the intent of the approach prodecure? (Granted an unlikely scenario, but the questions stands)
2. If the service volume for the localizer is 18NM as we learned from the threads posted above, wouldn't it be illegal for me to accept, or ATC to issue a clearance that provides an intercept outside 18NM? (20-30 mile intercepts seems fairly common from my experience)
1. I don't see how it would be, especially since charted stepdowns correspond with the glideslope at their respective distance, so you'd never be below them, if you stay on the G/S.
2. I don't think it would be, though I don't think they would issue such a clearance. They might put you at the minimum intercept altitude way far out, but I don't think they would have you intercept at MIA+2000' 30nm out or whatever.
Keep in mind also that even if you are on the GS, you are not considered past the FAF until you are on the G/S and at or below the MIA. Therefore, if the weather were to go sour while you were on the G/S but way above the MIA, you'd have to go missed.
I don't mean to sound stupid but do you mean that MIA = FAF were the lighting bolt is on the chart?
Yes, I believe so.
Check out the instrument procedures handbook, page 5-38.
The step down fixes that you are referring to are only for the localizer approaches. Usually there's a note on the approach plate telling you this. So if you lose your glideslope you would not descend to the MDA, stop at the step down fix and then after passing it descend to the MDA.
Theoretically, yes. If the ILS approach is designed in accordance with the current TERPS, any stepdown in the intermediate segment would be below the glideslope. That being said, there is anecdotal evidence that some approaches may have been designed with stepdowns that take you above the glide. I haven't ever seen one that clearly does, but be aware that the TERPS requirements can be modified in special circumstances, there just might be a special case with a stepdown above the glideslope. Regardless, be very aware of your position along the localizer and your altitude relativce to any intermediate stepdown fixes. Going below an intermediate altitude just might kill you. They don't add stepdowns to approaches just for entertainment. there's a reason, and often that reason is much tougher than you or your airplane.
This needs some clarification. For the stepdowns shown inside the FAF, your are correct, those apply to the LOC only procedure, not the ILS. The ones outside the FAF though, you do want to heed; those apply equally to the ILS or the LOC only approach.
Thanks for the replies. I learned the hard way at an interview the difference between the maltese cross and the lighting bolt. OOPS. Well, there staring pay scale was in the toilet anyway. I do understand that step down fixes outside the FAF are mandatory thanks to something else that is very hard. The fixes inside the FAF are for when you don't have the glideslope. Personally, on a localizer only or even a VOR, why drop like a rock to the MDA? Just set your VSI at a decent rate to where you arrieve at the MAP over the end of runway. Like 120kias you need about 550 fpm decent. This makes for a smoother ride.
1. Thanks for the replies. I learned the hard way at an interview the difference between the maltese cross and the lighting bolt.
2.Personally, on a localizer only or even a VOR, why drop like a rock to the MDA? Just set your VSI at a decent rate to where you arrieve at the MAP over the end of runway. Like 120kias you need about 550 fpm decent. This makes for a smoother ride.
1. really?? wow..
2. In my opinion, its better to be at the mda 'before' you reach the map.. it makes for a better transition if you have to go missed
Because it's more likely you will meet the requirements of Part 91.175 (c) and be able to land, rather than go missed.
OK, back to the original topic. Anyone want to explain why it's legal to intercept and track the localizer beyond 18 nm miles out as issued in many an approach clearance?
