It is a vent.
2 eletric boost pumps
1 Apu/x-flow pump
2 engine driven fuel pumps
2 primary ejectors "pumps"
2 scavenge ejectors "pumps"
2 transfer ejectors "pumps"
What the hell is a "jet pump"?
NACA scoop + garden hose + breath mint = Mesa Air Group fuel credit card.
Also called motive flow, A nozzle shoots fuel into the narrow most part of a venturi, the resulting low pressure area in the venturi pulls the fuel surrounding and behind the nozzle. This using a a little pressure tapped off the EDP or boost to move a larger quantity. It would resemble something like an old venturi pitot tube. Sort of like when you squirt a water hose in a pool the high speed stream pulls the still water with it.
Ah, I never heard the term "Jet pump" I knew what a motive flow pump was
