Ignition backup battery to replace the PS-1221S
aerolithium
Maker of Sodium Batteries
C310
Commercial
Since the etx104 has been used before, and is out of stock, I can provide either a custom fabbed 1221, 4Ah LFP unit with balancer
and DIY quick disconnects for $200
OR, better choice;
a more typical small cased battery. for $200
The ' 104 ' battery is 113 x 66 x 95 with 4ah , low discharge rated cells LFP type, with BMS ( which some may or may not want )
max discharge - 10A $179, 1.3 lbs, self discharge 3%/month ( bms's do have a tiny quiescent drain )
The balancing of the cells is the priority function.
Mine would offer a choice of BMS or no BMS, (balancer only)
case size; 110 x 66 x 105, weight 1.6 lbs, 5.0Ah, made of Sodium high rate cells, max discharge 100A
( higher the rate the less voltage drop under load )
As for charge current limiting, that would have to be handled external to the battery.
Both lithium and Sodium are fast charging cells.
Let me know what other info you require.
thanks
