As CVSfly wrote, "landing minimums", not "approach minimums" are controlling. What are the minimum requirements for landing from an instrument approach?
Landing minimums are addressed in 91.175 (d):
Landing: No pilot operating an aircraft, except a militart aircraft of the United States, may land that aircraft when the flight visibility is less than the visibility prescribed in the standard instrument approach procedure being used.
Furthermore, 121.651 (b) spells it out even more clearly:
Except as provided in paragraph (d) of this section, no pilot may continue an approach past the final approach fix, or where a final approach fix is not used, begin the final approach segment of an instrument approach procedure -
(2) At airports within the United States and its territories or at U.S. military airports, unless the latest weather report for that airport issued by the U.S. National Weather service, a source approved by that Service, or a source approved by the Administrator, reports the visibility minimums prescribed by that procedure...
(c) If a pilot has begun the final approach segment of an instrument approach procedure in accordance with paragraph (b) of this section and after that receives a later weather report indicating below-minimum conditions, the pilot may continue the approach to DH or MDA. Upon reaching DH or at MDA, and at any time before the missed approach point, the pilot may continue the approach below DH or MDA and touch down if -
(Paraphrased) The aircraft is continuously in a position to land in the touchdown zone using normal descent rates and maneuvers and the flight visibility is no less than the visibility prescribed for the approach.
From my freight experience, the ceiling is much less important than the visibility, particularly when shooting ILS approaches with sequenced flashing lights. I can't count the number of times I've gotten in easily with the weather 100&10, 100&3, 100& 1, etc. Remember, all you have to see at DH is those powerful strobe lights, then you can descend to 100 feet above TDZE. Looking down through a 100-200 foot thick cloud is much easier than looking through 1/4 mile-visibility fog that stretches for miles.
There is confusion at the FAA level though. I once did a 135 oral with the GRR FSDO. After completing it, I asked the Examiner this same question. He said he'd issue a violation immediately for flying an approach with ceiling below (approach) minimums. After he left, I went and found our P.O.I. at the FSDO and asked him the same question. He said the other examiner was wrong.
Hope this helps.
