The clock has to be wired into the aircraft. A yoke clip with a clock doesn't cut it
You must have learned TOMATO FLAMES as a child.JB74 said:I figured as much, just wondering where in the FAR/AIM (91.205 doesn't specify) to support an answer during an oral.
midlifeflyer said:You must have learned TOMATO FLAMES as a child.
You're making a very common error caused by the emphasis on memorizing this junk - thinking that 91.205 is a major part of the rules about equipment. It's actually very minor.
91.205 is a very generalized section that simply tells us the absolute minimum types of equipment that have to be on airplanes in order for them to be used in certain operations. It does not tell us even close to =all= of the equipment that is necessary for an operation, nor which equipment qualifies (does a wrist compass suffice for the magnetic compass requirement - if a stick on clock does, why not?)
So, if your airplane is modern enough to have a POH or AFM, go to it's equipment list and see whether "clock" is in the list as required equipment (or perhaps optional since it's not required for VFR) - if it is, =that's= the clock you need to have operable on the airplane (in the absence of a MEL)
Dutch said:How about the clock in the GPS that is installed in the aircraft. Every GPS I've come across has the system time listed on an aux page. Would this meet the requirement? (Just plalying devil's advocate)
Dutch
IP076 said:...As long as it displays seconds, it should be ok, I think the GX50 only displays hours and minutes...I'll have to check tonight...
pilotman2105 said:14 CFR 91.205(d)(6)
"A clock displaying hours, minutes, and seconds with a sweep-second pointer or digital presentation"
Your two cents, "Mav," aren't worth a quarter. (Apologies for mixing metaphors.)TopGun-MAV said:a very good question!
indeed you are legal to fly. as long as you have another form of time peace with a sweaping second hand.
just my 2 cents
IP076 said:Hey, you wrote that exactly as the reg....read it....displaying hours, minutes, and seconds with a sweep-second pointer OR digital presentation....Digital is fine.
bobbysamd said:(a) General. Except as provided in paragraphs (c)(3) and (e) of this section, no person may operate a powered civil aircraft with a standard category U.S. airworthiness certificate in any operation described in paragraphs (b) through (f) of this section unless that aircraft contains the instruments and equipment specified in those paragraphs (or FAA-approved equivalents) for that type of operation, and those instruments and items of equipment are in operable condition.
You're entirely welcome, my friend.pilotman2105 said:That's what I was looking for. I over looked that everytime I re-read the reg.
Thanks bobbysamd...
