Avbug - thanks for the info. I understand it's not rocket science, but I'm just used to seeing things a particular way, and this particular topic isn't as direct as most others are, i.e. specifically spelled out in the regulations (or at least the regs that I stick my nose into on a daily basis). I believe the AIM just fine, I just wanted to see something "regulatory". Call it professional research, if you will. I just wanted to know the "why", and between you and a couple others, I got the answer. Fair enough...thanks again.avbug said:They did. In the AIM...but you weren't content with what you were told by the AIM.
The 14 CFR ("FAR's) doesn't prescribe for you the loading limitations of your airplane, or powerplant limitations, or minimum or maximum airspeeds...these are certification issues, and the regulation that covers them is the aircraft type certificate data sheet, and type certificate itself...as well as the approved aircraft flight manual which contains such limitations.
That you don't find it in 14 CFR Part 91 doesn't surprise you, because you don't expect to find it there.
Likewise, that your onboard equipment may not be certified to meet the requirements of a particular regulatory requirement, doesn't mean that it needs to be published in the regulation. If you have a VFR-only GPS, for example, the regulation shouldn't be ammended to read "unless your GPS is approved for VFR-only." That's a given, and you know that because your equipment doesn't have that approval, it's not allowed to be used for primary IFR navigation.
Depending on your equipment, you may be able to file an airport equippped with only a GPS approach, as your alternate airport. But only if your onboard equipment is certified for it, and meets the appropriate Technical Standard Order. That's a TSO issue, not a regulatory issue...if your equipment doesn't meet the standards and can't do it, it can't do it, regulations not withstanding.
However...being as one of the quotes provided above came from the FAA Instrument FLight Training Handbook...this isn't rocket science. This is information presented to instrument students before they ever obtain their instrument rating. And it's printed in numerous places...you found it yourself in the AIM...just didn't want to accept it.
It's not an issue of not being printed in the specific regulation you seek...the information was available and you found it. It's an issue of w(h)eather you believe it or not. If don't believe it, then publishing it in a million places won't change that, will it?
