What is the desired idle RPM for a Lycoming IO-360? I have a modified IO-360 CubCrafters calls a 363i. Lightspeed ignition, fuel injected. My concern is the RPM is set too low. In my recent experience with bad coil packs I did extensive testing at idle, full throttle, and on each ignition side including both. My idle RPM as it came from the factory is around 560 RPM. That seems low to me and in testing I didn't let the engine quit but it sure seemed like it was about to. At each indication of the engine about to quit I pushed the throttle up to keep it running.
Today I decided to make an adjustment to the idle stop. Very easy to do and for those with a FX-3 like mine, it can be done through the left side "gill". I made an adjustment of the stop screw of about 3/4 turn and then ran it and that put it around 830 RPM which was a little too high for what I wanted, my desire is more around 700. So I backed out the screw a little, in the end it would be a 1/2 turn adjustment and I'm near 700 to 730. It idles much more reliably here. I'm going to make one more adjustment as I'd rather be in the 650-700 range and see how that works out.
I'm curious what others are showing for idle RPM and/or what is a stable RPM at the low end that can be expected? If anyone knows of any guidance from Lycoming I'd love to learn what you know.
