We get in there 3 or 4 times a month.... do yourself a favor and research all the ramp and taxiway closures prior to showing up there! Will save you a lot of grief!
The taxiways on the east side have been under heavy construction for the greater part of 6 months with no end in sight. If you're going to be using Executive Aircraft FBO, you'll have to drudge right thru all that to get to it.
Other then that, it's a big airport with a small airport feel, and the controllers are always friendly and cheerful to talk to.
If you're flying VFR, also make sure you do your homework on the big cluster of airports in the area as well - including one Air Force Base you'll defintely want to stay clear of!
