How exactly does an NDB work?
The loop antenna will line up in the direction from which the signal is coming from. It's called a loop antenna because they actually was a circular (hula hoop) antenna sticking out of an airplane. Check out pictures of WW2 era aircraft and you will see them. They actually had to tuen the loop by hand until they heard the strongest signal. The loop antenna will tell you that you are lined up with the signal, but you still don't know which way it is coming from. Think of the ADF needle without the needle pointer. It's just a line. Which way is it coming from??
The sense antenna figures out which way the signal is coming from. It places the needle pointer on the needle. On older aircraft, the sense antenna is the long wire which strecthes from nose to tail. On modern ones, the loop and sense are all combined into a big fat lump antenna on the bottom of the aircraft.
Each antenna is pretty useless without the other.
So you think NDB are dead huh,
Going into SAT about 2 months ago, the guy that I was flying with same the exact same thing and then the ILS went completely down. So guess what was left....NDB only. NDB are great if you know how to use them. I can see a lot of Barbie Dream jet pilots think they are antiquated but there are still are lot a large transport airplanes out there that dont have FMS or glass.
I still say if you can shoot a NDB appraoch you can do the rest of them fairly easily.
But I still think the NDB's time has passed!
wrong..... You may not use them but I can tell you that flying into certain airports in Canada you have only one approach and one option, the NDB. Even though this country may be doing away with them you still need to know how to safely execute the approach due to other places that still use them quite often. I will never forget my first trip as captain flying 135 up into Canada going into a small airport that only had 1 approach, yup the NDB approach... You need to know how to fly them unless you want to chance making a fool out of yourself at some point down the line.
NDB's......
If the FMS cant do it, it should not be done.
How many part 135 pilots hauling night freight have the luxury of having a FMS onboard? Kind of thought so.....
3 5 0
HerrJeremy said:
Right, that's my question. How does the sense antenna do that?
I have no idea, I'm not an avionics technician. Only they need to know that.
All I remember is way back when I was a cadet in the Civil Air Patrol at age 12 or 13, they would hide a fake ELT (that transmitted on something other than 121.5) for practice and we had this contraption with an antenna which looked like an H. It would beep when the signal was in range, then we would hold it upright and spin around until the beeping was loudest. Then we would turn on "sense" mode and turn the unit until it beeped again. It had an arrow on it pointing to one of the sides of the H antenna. When it beeped, that meant the one side was in line with the signal. Then we would go that way and find the ELT. It was pretty fun, but not nearly as fun as riding in a C-130 to go to the Smithsonian.
Hey there,
There is a sport called radio orientearing, or ARDF. Someone hides a radio transmitter and you have to go find it using something similiar to an ADF.
http://members.aol.com/homingin/equipment.html
Also I am not sure if I am correct or not, but I always thought that aviation frequencies even in the VHF band were modulated as VHF AM signals. So you would not be able to listen to VHF FM radio even if you wanted to and also the VOR band is put higher than VHF FM so that there should not be any interference.
The NDB always had the ability to pick up AM broadcast, as in days gone bye you could see where towers were on the map and what the name of the station was, this is why they always do name checks so often. Nowadays with companies having so many repeater stations and clear channel communication telling everyone what they should listen to it is not so easy.
You can also if you live in a Marine environment, tune in Marine marker beacons on the coast. They use them up north in Canada, the only problem is that they can be seasonal. And you also have coastal refraction errors.
Anyways I still think that it is a goos idea to teach them, as not everyone gets to jump into new plane with GPS or FMS.
-273
