Holy crap, I lost my engine last night...
My, my, MTR. You're quite the five hundred hour expert.
The poster who started the thread posted because he lost his engine. Seems that he found out carb heat ought to be used, didn't he?
Carb heat is a tool. It's there to be used as needed. The assertion that it's all or nothing is an ignorant one. It's a blanket idiot statement, much like assertions regarding minimum altitudes for leaning...and operations lean of peak.
Sounds to me like you're a book warrior...probably think that ground effect is a cushion of air beneath the wing, that lean of peak operation is hotter than rich of peak, that the downwind turn doesn't exist, and that the wrights were the first in flight. Believe what you will.
As for the green arc representing anything to do with carburetor heat, it doesn't. Nor does the yellow arc, which is typically an RPM range to avoid under certain conditions due to blade harmonics.
Additionally, being in the green arc doesn't suggest the engine is driving the prop, as it doesn't take into account slipstream velocity and it's effect on the propeller. A dive at idle may place the prop well into the green arc, while clearly the wind is driving the prop and not the engine.
As for MTR's assertions regarding POH/AFM use of carburetor heat...I said nothing about ground operations, and the discussion here speaks nothing toward prolonged use of carb heat on the ground. Accordingly, your introduction of this into the discussion is an effort to cloud the issue, not contribute. Likewise, your includsion of information regarding detonation on a go-around serves nothing to address the topic.
Yes, full carburetor heat may lead to detonation at power settings above 75%...assuming the pilot is an idiot. But partial carburetor heat may not...and that's your beef here...you don't have the experience to know that it's far from always full or nothing. Have you ever used a carburetor air temp gauge? Have you ever experienced an engine failure due to carburetor icing? Have you ever operated an aircraft with each kind of carburetor installation out there, and been able to make the comparison? Have you ever had proper instruction in the use of carburetor heat?
It's a misunderstood topic, and one in which most pilots don't get proper training. That you don't understand it isn't surprising.
Avbug brought up some common fallacies pilots have on some issues. Since he only mentioned them, I thought I'd clarify them for anyone who isnt familiar with them.
Leaning may be accompished at ANYTIME as long as the power is below 75%. While taxiing, leaning has NO effect if the throttle is at idle. At Idle, a separate fuel jet is suppling fuel to the engien and moving the mixture lever does nothing.
It's a misconception that the wing is compressing air below it and allowing the wing to rest on it. When the wing is within its wingspan of the ground and more so closer than this, you will encounter a decrease in upwash, downwash and wingtip vortices. This has the effect of decreasing the induced drag generated by the wing and consequently cuts the drag associate with it. The reduction in drag allows the wing to develop a greater coefficient of lift at the same angle of attack, therby allowing this additional lift to create a "floating" over and down the runway.
Sounds like a paradox, but rich of peak is hotter than lean of peak. Since rich causes more fuel to enter the cylinders for combustion, it creates higher operating temperatures. This is no different that observing engine temp rise with an RPM going from 500 to 2300. More power equals greater heat combustion translating into higher temps. At lean settings you deprive the engine of fuel and thus increase the economy. Intially, the temp will rise while leaning, but then drop down as engine is deprived of fuel. Lower temps require less additonal fuel for cooling.
When the plane is on the ground during a runup, the tach needle goes from outside to inside of the green arc. There is no wind component turning the blade on the ground. The engine is turning the prop outside fothe arc. Not sure who told the original poster this, but the green arc has nothign to do with whether the wind or engine is turnign the prop in a constant speed propeller.
I thought it was about experience, not hours. What ever happened to the "if you want hours, buy a good pen" (paraphrased) posts?
-mini
FAA's Airplane Flying Handbook Page 11-6 & 11-7
Some important points to remember concerning constant-speed propeller operation are:
  • The green arc on the tachometer indicates the normal operating range. When developing power in this range, the engins drives the propeller. Below the green arc, however, it is usually the windmilling propeller that powers the engine. Prolonged operation below the green arc can be detrimental to the engine.
I am pretty sure they mean while in flight.
I learned something new. Thanks.
First of all, I'm NOT getting into the mud-slinging and name calling. Please don't take this as a personal attack. :)
You can keep the carb heat on continuously during cruise. Just lean it out.
I don't like this because what happens if you do get carb ice? Now what do you do? It would be tough but still possible to get carb ice with the heat on, but it takes away an option. All of my flying with carbureted engines has been in TX, OK, CA and PA not in high lattitudes. All of my friends and students who flew in Alaska said they would never leave carb heat on all the time unless there were severe conditions and they were in the process of landing.
My $.02.
-JP
Could you check that page number again? My FAA Airplane Flying Handbook (Revised 1999) has Navigation info in Chapter 11.
I have the 2004 revision. Should have mentioned that but I forgot.
Not that it matters too much, but here is a little more clarification.... I was finishing an IFR flight and the temps were around 40 ish with visible moisture inflight. Kept a good eye out for ice (saw none) and did have to apply the carb heat a few times during the flight. On final I got a slight surge in RPMs and actually thought my wif had bumped the throttle lever. Since I was so close to landing anyway (and my experience showed me that a surge meant ice was clearing), I decided not to mess with the carb heat again and then the rest is history....
Worst part is that my WHOLE family was in that plane. My 2 year old daughter was innocently asleep in the back.
I think the biggest point anyone can make is to know what the recommendations are for the plane you fly and always try to have at least a basic understanding of the concepts that affect your flight and situation. In Navy aviation the old saying is that NATOPS (the operating procedures for a given platform) is written in blood.
By the way, I don't like the carb heat and lean idea for cruise. As someone else stated, what would be your alternative for clearning an icing condition? I guess you could say that you wouldn't have one, but that is arguable.
dhc8fo said:
...what would be your alternative for clearning an icing condition?
Exactly.
Back to the point, glad it worked out. And what a great lesson. Thanks for sharing it.
-JP
Question i was asked on my CFI checkride....
What are the certification standards for carb heat on airplanes?
In other words, how many degrees (Fahrenheit) must the temperature increase and at what power setting must it be able to do that?
Anybody got a clue? My guess is Avbug knows, as he knows everything else too :).
I know the answer, and will share it in a bit ;). Just curious if anyone else knows or if i was the only dumb-shat who didn't know that.
If I got asked that on my CFI ride I would have gotten up and left the building!
My guess would be at least 40 degrees (f) at any power setting.
Did I get it?
Did I get it?
Have to agree...think I would have asked for a letter of discontinuance and said thanks, keep the change.
I'll go ten more...50(f) and I'll go with 65-75%?
-mini
*edit*
Honestly, now that I think for a bit...I wouldn't have left. I would have said "I honestly have no idea, but I bet I know how to find out..." and taken a look in the FAR/AIM. Probably a better answer and a lot more mature...
There's no reason to get up and leave for any question. That is, as long as he doesn't fail one for it. He didn't. I think he was just curious if i knew or not. There was quite a bit i didn't know where he didn't fail me on. But i did screw up on a different part, but thats another story.
My response was simply that i had no clue and never even heard of such a standard. I don't think you would find the answer in the AIM. I suppose it would be in part 21 or something, since that deals with certification of parts.
But the answer is the Carb heat must increase the air temp by at least +90 degrees fahrenheit at 75% power.
Anyway - to relate this to engine performance for those who suggest to fly with constant carb heat on.... you'd automatically increase your DA in your engine manifold by 4000ft - that is, if my calculations are correct ;)
And as a CFI, you give a sh!t about that for what reason?
