HKG Info
ChinaClipper
How far is the Terminal from the Cargo ramp? How does one get from Cargo to the Terminal? skypier? Trains to HK Island or Kowloon? Thanks mucho!!!!
Your company should provide you with transport to the terminal, which is across the airport. Going through the terminal is the only way to enter the country. Skypier is attached to the airport.
Trains leave the airport every 12 minutes to Kowloon and Hong Kong. It takes about 20 min to get to either.
If you are jumpseating in, as Bjammin says, you will have to ride the bus with the crew and process in at the main terminal!
