nosehair
- Sep 22, 2003
Re: Re: LANDING TECH-TIPS (add to the above information)
I see someone has heartburn about the old "pitch to the airspeed, power to the altitude" line....
Me too! You are early enough in your training to , maybe, not get sucked into that black hole. If you develop the habit of pitching to the airspeed on final, when you have heat thermals on final, you will have some days when you "just cain't git down".
When energy from the sun is transferred to our airplane via thermals, that energy has to be used somewhere. If you are in level flight, and you get an updraft, a slight increase in altitude, do you power back? Do you "power to the altitude"? No, you probably don't. You "pitch to the altitude", and allow the airspeed to increase a little. If the airspeed icrease is too much, you power back a little. The same is true on approaches. Normal approaches, that is, when your final approach airspeed is at or above max L/D. Below that speed, as in short field approaches, yes, you power to the altitude and pitch to the airspeed. But that is NOT a normal approach.
Believe me: if you pitch the nose down and aim it at the numbers, and KEEP pitching to the altitude(glideslope), and power back or up to control airspeed, you will consistantly make better, more stabilized approaches.
Try the flare in two parts: Keep the approach speed and glidepath down to about tree-top, or hanger-top height, then apply just enough elevator back pressure to LEVEL the nose with the runway. Keep it level momentarily as the speed bleeds off. Your power is idle. As the speed bleeds off, and you are looking at the far end of the runway down the centerline, as you see the airplane sinking down into the runway, try to imagine you are trying to FLOAT the airplane down the entire length of the runway. When it runs out of flying speed it will land - nose high, on the mains. KEEP THAT WHEEL BACK -just like the space shuttle landing. Slowly, as speed drops off ease the nose-wheel down to "land" the nose-wheel. Keep your eyes on that centerline and keep steering with your rudder and keep elevator back-pressure on the elevator to keep excessive pressure off the nose-wheel strut, and keep that aileron cross-wind control in while you steer this machine straight down the centerline on roll-out. Apply smooth, even braking to effect a smooth turn-off and look over at the big, toothy grin on your instructor's face.
Singlecoil said:Oh no, here we go again.
